1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: camonitor vs caput
From: Rolf Keitel via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 5 Dec 2023 11:00:33 -0800
Title: signature text
I am not 100% sure if my answer applies to the the I/O Intr scan, but:
When you caput to a record (I am assuming you put to the VAL field, for other fields you need to consult the record reference documentation), this causes the record to *process*. The input link(s) will be processed and the VAL field will be updated (i.e. the value you just put with caput will be clobbered). If the VAL field changes by more than the monitor delta, the record will issue a monitor, otherwise not.
HTH - rolf -
On 2023-12-05 8:12 a.m., Gerrit Kühn via Tech-talk wrote:
Am Tue, 5 Dec 2023 15:26:16 +0000
schrieb Érico Nogueira Rolim <[email protected]>:
 From [1]:
Passive records are processed when they are referenced by other
records through their link fields or when a channel access put is done
to them.
Um, yes, but the record in question isn't passive, it's I/O Intr. It does
not say "*Only* passive records are processed...".
A record must be Passive in order to be *processed* (therefore sending
an event to your camonitor process) when it receives a value write.
I do not understand this from what you quoted. The quote is only on
passive records and says nothing about I/O Intr. Further below it even
says on processing
For output links, this option allows a request for remote processing
(side-effects).
none (default) - Make no special request. Uses a server specific default.
false, “NPP” - Request to skip processing.
true, “PP” - Request to force processing.
“CP”, “CPP” - For output links, an alias for “PP”.
I even tried that (writing values from a calcout record to the I/O Intr
record using PP), but camonitor did not take notice on that case, either.
I believe a possible workaround would be an auxiliary record(s), first
writing the value and then writing to "$record.PROC CA". I know that
works to force processing for records with periodic scanning, but don't
remember testing with I/O Intr.
Would that be considered a better/cleaner solution than what I already came
up with (using an auxilary record for I/O Intr and having the actual data
record passive)?
cu
  Gerrit
Rolf Keitel, Ph.D.
Researcher Emeritus
e-mail: [email protected]
------ Home ------
4158 West 13th Ave
Vancouver, BC, V6R 2T6
604 228 0594
------ Office: ------
604 222 7453
TRIUMF Canada’s particle accelerator centre
4004 Wesbrook Mall Vancouver, BC, V6T 2A3
www.triumf.ca | Twitter | Facebook | Instagram
TRIUMF is located on the traditional, ancestral, and unceded territory of the xʷməθkʷəy̓əm (Musqueam) people,
who for millennia have passed on their culture, history, and traditions from one generation to the next on this site.
camonitor vs caput Gerrit Kühn via Tech-talk
Re: camonitor vs caput Gerrit Kühn via Tech-talk
Re: camonitor vs caput Érico Nogueira Rolim via Tech-talk
Prev: Re: camonitor vs caput Gerrit Kühn via Tech-talk
Next: Re: camonitor vs caput Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
