Am Tue, 5 Dec 2023 15:26:16 +0000
schrieb Érico Nogueira Rolim <erico.rolim at lnls.br>:
> From [1]:
> Passive records are processed when they are referenced by other
> records through their link fields or when a channel access put is done
> to them.
Um, yes, but the record in question isn't passive, it's I/O Intr. It does
not say "*Only* passive records are processed...".
> A record must be Passive in order to be *processed* (therefore sending
> an event to your camonitor process) when it receives a value write.
I do not understand this from what you quoted. The quote is only on
passive records and says nothing about I/O Intr. Further below it even
says on processing
For output links, this option allows a request for remote processing
(side-effects).
none (default) - Make no special request. Uses a server specific default.
false, “NPP” - Request to skip processing.
true, “PP” - Request to force processing.
“CP”, “CPP” - For output links, an alias for “PP”.
I even tried that (writing values from a calcout record to the I/O Intr
record using PP), but camonitor did not take notice on that case, either.
> I believe a possible workaround would be an auxiliary record(s), first
> writing the value and then writing to "$record.PROC CA". I know that
> works to force processing for records with periodic scanning, but don't
> remember testing with I/O Intr.
Would that be considered a better/cleaner solution than what I already came
up with (using an auxilary record for I/O Intr and having the actual data
record passive)?
cu
Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- Re: camonitor vs caput Rolf Keitel via Tech-talk
- camonitor vs caput Gerrit Kühn via Tech-talk
- Re: camonitor vs caput Gerrit Kühn via Tech-talk
- Re: camonitor vs caput Érico Nogueira Rolim via Tech-talk
<2023>
<2023>
