1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: EPICS build problem
From: Federico Galdenzi via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 29 Apr 2025 11:05:04 +0200
Dear Freddie and Mark, thanks again for your help. As you can see here in the logs i still have the bug of not finding stdio.h and assert.h in my computer. I know that this is basic but i cant' really find a solution.
Regards, Federico.
Il 2025-04-16 17:42 Freddie Akeroyd - STFC UKRI ha scritto:
The windows.bat / win32.bat files just run vcvarsall.bat, set EPICS_HOST_ARCH and add perl to the PATH, so are just convenient shortcuts and not strictly necessary
When vcvarsall.bat is run it needs an argument to tell it the build architecture, and this needs to match your intended EPICS_HOST_ARCH. So try
    vcvarsall.bat x64
    set EPICS_HOST_ARCH=windows-x64
for a 64bit build. If you needed a 32bit built it would be:
    vcvarsall.bat x86
    set EPICS_HOST_ARCH=win32-x86
Freddie
-----Original Message-----
From: Federico Galdenzi <galdenzi at roma2.infn.it>
Sent: 16 April 2025 14:18
To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
Cc: Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov
Hi Freddie,
I've followed this part of the tutorial:
Download the distribution from e.g.
https://urldefense.us/v3/__https://epics-controls.org/download/base/base-7.0.4.1.tar.gz__;!!G_uCfscf7eWS!dOUGuC5alojQQeV-ry92ny1Way1m7cxAKtpjVYz-kNnx8pEAq1NOJpXvRD7J2doRelzSTsPhxCTcXqtIXkR-Khx1ScE$ .
Unpack it into a work directory.
Open a Windows command prompt and change into the directory you unpacked EPICS Base into.
Note: The complete path of the current directory mustn’t contain any spaces or parentheses. If your working directory path does, you can do another cd into the same directory, replacing every path component containing spaces or parentheses with its Windows short path (that can be displayed with dir /x).
Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for 64bit builds, win32-x86 for 32bit builds).
Run the vcvarsall.bat script of your installation (the exact path depends on the type and language of installation) to set the environment for your build.
Run make (or gmake if using the version from Strawberry Perl).
When i cd to my folder, and typed "where cl" it doesnt' return anything not even after i ran the vcvarsall.bat. I didnt' ran the windows.bat because it wasn't written.
Should i do it directly from the folder?
Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
In the startup directory of epics there are two bat files  "win32.bat"
and "windows.bat" - which did you use to setup the compiler path etc. ?
 win32.bat choses the compiler for 32bit builds and windows.bat for
64bit builds. Your EPICS_HOST_ARCH environment variable is set for a
64bit builds, but the error message suggests your build may be using
the 32bit compiler instead as the linker cannot target x64. If you
type
    where cl
do you see a path with x64 in it like
    C:\Program Files\Microsoft Visual
Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.ex
e
Or do you see x86 present instead?
Freddie
Sent: 16 April 2025 08:15
To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>;
Cc: tech-talk at aps.anl.gov
Thanks in advance for the help. I made the log for make and also i can
tell that i'm following by letter the tutorial that i've linked to
download and build epic base. I've installed perl and make manually.
Best regards.
Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
We'll need to see a bit more of your build log to see exactly which
libraries it is having a problem with, can you please post the whole
build log by doing  something like
    make clean uninstall
    make > make.log 2>&1
And posting make.log
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of
Sent: 15 April 2025 12:36
Subject: EPICS build problem
Good morning all,
I have a problem for installing EPICS on my machine. I've followed
the instruction given in this site:
https://urldefense.us/v3/__https://docs.epics-
controls.org/en/latest/getting-started/installation-windows-
plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
q5862JV6Ua7PGUqoY-cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
but it seems that i'm missing something, because i get the "make"
fatal error
LNK1112: module machine type 'x86' conflicts with target machine
type 'x64'.
I'm kinda new to this world but i cant' manage to understand what
i'm doing wrong. It seems that i'm using 32 bit libraries on a 64
bit environment, but i'm using Visual Studio latests kit's for
developing in C++ in both 64 and
32 bit.
What can i do?
ÿþC:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./configure install
make[1]: Entering directory 'C:/Epics/base-7.0.9/configure'
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/Epics/base-7.0.9/configure/O.windows-x64'
cl -nologo -C -E               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include         ../toolchain.c > TOOLCHAIN.windows-x64.windows-x64
make : toolchain.c
In riga:1 car:1
+ make 2>&1 | tee make.txt
    + CategoryInfo          : NotSpecified: (toolchain.c:String) [], RemoteException
    + FullyQualifiedErrorId : NativeCommandError
"Installing CFG file ../../cfg/TOOLCHAIN.windows-x64.windows-x64"
mkdir ../../cfg
"Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE"
"Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION"
"Installing CFG file ../../cfg/CONFIG_CA_MODULE"
"Installing CFG file ../../cfg/CONFIG_CA_VERSION"
"Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE"
"Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION"
make[2]: Leaving directory 'C:/Epics/base-7.0.9/configure/O.windows-x64'
make[1]: Leaving directory 'C:/Epics/base-7.0.9/configure'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./src install
make[1]: Entering directory 'C:/Epics/base-7.0.9/src'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./tools install
make[2]: Entering directory 'C:/Epics/base-7.0.9/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.windows-x64 ../../..
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/Epics/base-7.0.9/src/tools/O.windows-x64'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/PodHtml.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/PodMD.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/PodXHtml.pm"
"Installing PERL_MODULES file ../../../lib/perl/Pod/Markdown.pm"
mkdir ../../../lib/perl/Pod
"Installing PERL_MODULES file ../../../lib/perl/URI/Escape.pm"
mkdir ../../../lib/perl/URI
"Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Use of uninitialized value in sprintf at C:/Strawberry/perl/lib/Pod/Simple/HTML.pm line 332.
"Installing generated html ../../../html/./EPICS/Getopts.html"
mkdir ../../../html/./EPICS
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
"Installing generated html ../../../html/./EPICS/Path.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
"Installing generated html ../../../html/./EPICS/Readfile.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
"Installing generated html ../../../html/./fullPathName.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o makeAPIheader.html ../makeAPIheader.pl
"Installing generated html ../../../html/./makeAPIheader.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
"Installing generated html ../../../html/./munch.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToHtml.html ../podToHtml.pl
"Installing generated html ../../../html/./podToHtml.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToMD.html ../podToMD.pl
"Installing generated html ../../../html/./podToMD.html"
perl -CSD ../../../src/tools/podToHtml.pl -s -o podRemove.html ../podRemove.pl
"Installing generated html ../../../html/./podRemove.html"
"Installing script ../../../bin/windows-x64/assembleSnippets.pl"
mkdir ../../../bin
mkdir ../../../bin/windows-x64
"Installing script ../../../bin/windows-x64/convertRelease.pl"
"Installing script ../../../bin/windows-x64/cvsclean.pl"
"Installing script ../../../bin/windows-x64/depclean.pl"
"Installing script ../../../bin/windows-x64/dos2unix.pl"
"Installing script ../../../bin/windows-x64/epicsProve.pl"
"Installing script ../../../bin/windows-x64/expandVars.pl"
"Installing script ../../../bin/windows-x64/filterMakeflags.pl"
"Installing script ../../../bin/windows-x64/fullPathName.pl"
"Installing script ../../../bin/windows-x64/installEpics.pl"
"Installing script ../../../bin/windows-x64/makeAPIheader.pl"
"Installing script ../../../bin/windows-x64/makeMakefile.pl"
"Installing script ../../../bin/windows-x64/makeTestfile.pl"
"Installing script ../../../bin/windows-x64/mkmf.pl"
"Installing script ../../../bin/windows-x64/munch.pl"
"Installing script ../../../bin/windows-x64/podToMD.pl"
"Installing script ../../../bin/windows-x64/podToHtml.pl"
"Installing script ../../../bin/windows-x64/podRemove.pl"
"Installing script ../../../bin/windows-x64/replaceVAR.pl"
"Installing script ../../../bin/windows-x64/tap-to-junit-xml.pl"
"Installing script ../../../bin/windows-x64/testFailures.pl"
"Installing script ../../../bin/windows-x64/useManifestTool.pl"
"Installing script ../../../bin/windows-x64/genVersionHeader.pl"
"Installing script ../../../bin/windows-x64/makeRPath.py"
make[3]: Leaving directory 'C:/Epics/base-7.0.9/src/tools/O.windows-x64'
make[2]: Leaving directory 'C:/Epics/base-7.0.9/src/tools'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C template/base install
make[2]: Entering directory 'C:/Epics/base-7.0.9/src/template/base'
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../../..
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory 'C:/Epics/base-7.0.9/src/template/base/O.windows-x64'
"Installing script ../../../../bin/windows-x64/makeBaseApp.pl"
"Installing ../../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
"Installing ../../../../templates/makeBaseApp/top/.gitignore"
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseApp/top/configure
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP"
make[3]: Leaving directory 'C:/Epics/base-7.0.9/src/template/base/O.windows-x64'
make[2]: Leaving directory 'C:/Epics/base-7.0.9/src/template/base'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C template/ext install
make[2]: Entering directory 'C:/Epics/base-7.0.9/src/template/ext'
make[3]: Entering directory 'C:/Epics/base-7.0.9/src/template/ext/O.windows-x64'
"Installing script ../../../../bin/windows-x64/makeBaseExt.pl"
"Installing ../../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
"Installing ../../../../templates/makeBaseExt/top/.gitignore"
"Installing ../../../../templates/makeBaseExt/top/README"
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseExt/top/configure
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-aarch64.darwin-aarch64"
mkdir ../../../../templates/makeBaseExt/top/configure/os
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-aarch64.linux-aarch64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64"
"Installing ../../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../../templates/makeBaseExt/top/src
"Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory 'C:/Epics/base-7.0.9/src/template/ext/O.windows-x64'
make[2]: Leaving directory 'C:/Epics/base-7.0.9/src/template/ext'
make[1]: Leaving directory 'C:/Epics/base-7.0.9/src'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./test install
make[1]: Entering directory 'C:/Epics/base-7.0.9/test'
make[2]: Entering directory 'C:/Epics/base-7.0.9/test/tools'
make[3]: Entering directory 'C:/Epics/base-7.0.9/test/tools/O.windows-x64'
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/expandVars.pl  -t ../../.. -a windows-x64 ../Snippets.plt Snippets.t
make[3]: Leaving directory 'C:/Epics/base-7.0.9/test/tools/O.windows-x64'
make[2]: Leaving directory 'C:/Epics/base-7.0.9/test/tools'
make[1]: Leaving directory 'C:/Epics/base-7.0.9/test'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./modules install
make[1]: Entering directory 'C:/Epics/base-7.0.9/modules'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./libcom install
make[2]: Entering directory 'C:/Epics/base-7.0.9/modules/libcom'
make[3]: Entering directory 'C:/Epics/base-7.0.9/modules/libcom/src'
make[4]: Entering directory 'C:/Epics/base-7.0.9/modules/libcom/src/O.windows-x64'
"Expanding ../libComVersion.h@ to ../O.Common/../O.Common/libComVersion.h"
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/expandVars.pl  -t ../../../.. -D INSTALL_BIN=C:/Epics/base-7.0.9/bin/windows-x64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="24"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="0"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="0"  ../libComVersion.h@ ../O.Common/libComVersion.h
perl -CSD ../misc/makeEpicsVersion.pl -o epicsVersion.h   ../../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 7.0.9
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/makeAPIheader.pl -o ../O.Common/libComAPI.h libCom
"Installing generated generic include file ../../../../include/libComAPI.h"
mkdir ../../../../include
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/makeAPIheader.pl -o ../O.Common/dbCoreAPI.h dbCore
"Installing generated generic include file ../../../../include/dbCoreAPI.h"
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m ccl.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         ccl.obj ../flex/ccl.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m dfa.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         dfa.obj ../flex/dfa.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m ecs.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         ecs.obj ../flex/ecs.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m gen.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         gen.obj ../flex/gen.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m misc.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         misc.obj ../flex/misc.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m nfa.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         nfa.obj ../flex/nfa.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m sym.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         sym.obj ../flex/sym.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m tblcmp.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         tblcmp.obj ../flex/tblcmp.c
"Installing generic include file ../../../../include/valgrind/valgrind.h"
mkdir ../../../../include/valgrind
"Installing generated generic include file ../../../../include/libComVersion.h"
"Installing generic include file ../../../../include/asLib.h"
"Installing generic include file ../../../../include/asTrapWrite.h"
"Installing generic include file ../../../../include/bucketLib.h"
"Installing generic include file ../../../../include/postfix.h"
"Installing generic include file ../../../../include/cvtFast.h"
"Installing generic include file ../../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../../include/resourceLib.h"
"Installing generic include file ../../../../include/tsDLList.h"
"Installing generic include file ../../../../include/tsSLList.h"
"Installing generic include file ../../../../include/tsMinMax.h"
"Installing generic include file ../../../../include/tsFreeList.h"
"Installing generic include file ../../../../include/epicsSingleton.h"
"Installing generic include file ../../../../include/epicsGuard.h"
"Installing generic include file ../../../../include/dbmf.h"
"Installing generic include file ../../../../include/ellLib.h"
"Installing generic include file ../../../../include/envDefs.h"
"Installing generic include file ../../../../include/epicsPrint.h"
"Installing generic include file ../../../../include/errMdef.h"
"Installing generic include file ../../../../include/errSymTbl.h"
"Installing generic include file ../../../../include/errlog.h"
"Installing generic include file ../../../../include/fdManager.h"
"Installing generic include file ../../../../include/fdmgr.h"
"Installing generic include file ../../../../include/flex.skel.static"
"Installing generic include file ../../../../include/freeList.h"
"Installing generic include file ../../../../include/gpHash.h"
"Installing generic include file ../../../../include/iocsh.h"
"Installing generic include file ../../../../include/initHooks.h"
"Installing generic include file ../../../../include/registry.h"
"Installing generic include file ../../../../include/libComRegister.h"
"Installing generic include file ../../../../include/iocLog.h"
"Installing generic include file ../../../../include/logClient.h"
"Installing generic include file ../../../../include/macLib.h"
"Installing generic include file ../../../../include/alarm.h"
"Installing generic include file ../../../../include/alarmString.h"
"Installing generic include file ../../../../include/adjustment.h"
"Installing generic include file ../../../../include/cantProceed.h"
"Installing generic include file ../../../../include/dbDefs.h"
"Installing generic include file ../../../../include/epicsConvert.h"
"Installing generic include file ../../../../include/epicsExit.h"
"Installing generic include file ../../../../include/epicsStdlib.h"
"Installing generic include file ../../../../include/epicsString.h"
"Installing generic include file ../../../../include/epicsTypes.h"
"Installing generic include file ../../../../include/shareLib.h"
"Installing generic include file ../../../../include/epicsExport.h"
"Installing generic include file ../../../../include/locationException.h"
"Installing generic include file ../../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../../include/compilerDependencies.h"
"Installing generic include file ../../../../include/epicsUnitTest.h"
"Installing generic include file ../../../../include/testMain.h"
"Installing generated generic include file ../../../../include/epicsVersion.h"
"Installing compiler dependent include file ../../../../include/compiler/msvc/compilerSpecific.h"
mkdir ../../../../include/compiler
mkdir ../../../../include/compiler/msvc
"Installing generic include file ../../../../include/osiFileName.h"
"Installing generic include file ../../../../include/osiSock.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdSock.h"
mkdir ../../../../include/os
mkdir ../../../../include/os/WIN32
"Installing generic include file ../../../../include/epicsInterrupt.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../../include/epicsMutex.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../../include/epicsSpin.h"
"Installing generic include file ../../../../include/epicsEvent.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdEvent.h"
"Installing OS dependent include file ../../../../include/os/WIN32/epicsMath.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdMessageQueue.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../../include/epicsAssert.h"
"Installing generic include file ../../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../../include/osiPoolStatus.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdPoolStatus.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../../include/epicsThread.h"
"Installing generic include file ../../../../include/epicsTime.h"
"Installing generic include file ../../../../include/epicsGeneralTime.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../../include/generalTimeSup.h"
"Installing generic include file ../../../../include/osiClockTime.h"
"Installing generic include file ../../../../include/epicsSignal.h"
"Installing generic include file ../../../../include/osiProcess.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../../include/osiWireFormat.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdWireFormat.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../../include/epicsAtomic.h"
"Installing generic include file ../../../../include/epicsAtomicDefault.h"
"Installing OS dependent include file ../../../../include/os/WIN32/epicsAtomicOSD.h"
"Installing compiler dependent include file ../../../../include/compiler/msvc/epicsAtomicCD.h"
"Installing generic include file ../../../../include/epicsEndian.h"
"Installing generic include file ../../../../include/epicsReadline.h"
"Installing generic include file ../../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../../include/epicsStdio.h"
"Installing generic include file ../../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../../include/epicsTempFile.h"
"Installing OS dependent include file ../../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../../include/epicsStackTrace.h"
"Installing generic include file ../../../../include/devLib.h"
"Installing generic include file ../../../../include/devLibVME.h"
"Installing generic include file ../../../../include/devLibVMEImpl.h"
"Installing OS dependent include file ../../../../include/os/WIN32/osdVME.h"
"Installing OS dependent include file ../../../../include/os/WIN32/epicsMMIO.h"
"Installing OS dependent include file ../../../../include/os/WIN32/epicsMMIODef.h"
"Installing generic include file ../../../../include/epicsThreadPool.h"
"Installing generic include file ../../../../include/epicsRingPointer.h"
"Installing generic include file ../../../../include/epicsRingBytes.h"
"Installing generic include file ../../../../include/taskwd.h"
"Installing generic include file ../../../../include/epicsTimer.h"
"Installing generic include file ../../../../include/yajl_alloc.h"
"Installing generic include file ../../../../include/yajl_common.h"
"Installing generic include file ../../../../include/yajl_gen.h"
"Installing generic include file ../../../../include/yajl_parse.h"
"Installing OS dependent include file ../../../../include/os/WIN32/epicsAtomicMS.h"
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../yacc/closure.c
closure.c
C:\Epics\base-7.0.9\modules\libcom\src\yacc\defs.h(1): fatal error C1083: Cannot open include file: 'assert.h': No such file or directory
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m iocLogServer.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         iocLogServer.obj ../log/iocLogServer.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m closure.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         closure.obj ../yacc/closure.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m error.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         error.obj ../yacc/error.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m lalr.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         lalr.obj ../yacc/lalr.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m lr0.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         lr0.obj ../yacc/lr0.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m antelope.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         antelope.obj ../yacc/antelope.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m mkpar.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         mkpar.obj ../yacc/mkpar.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m output.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         output.obj ../yacc/output.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m reader.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         reader.obj ../yacc/reader.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m skeleton.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         skeleton.obj ../yacc/skeleton.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m symtab.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         symtab.obj ../yacc/symtab.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m verbose.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         verbose.obj ../yacc/verbose.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m warshall.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         warshall.obj ../yacc/warshall.c
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../flex/ccl.c
ccl.c
C:\Epics\base-7.0.9\modules\libcom\src\flex\flexdef.h(32): fatal error C1083: Cannot open include file: 'stdio.h': No such file or directory
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m asTrapWrite.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         asTrapWrite.obj ../as/asTrapWrite.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m bucketLib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         bucketLib.obj ../bucketLib/bucketLib.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m postfix.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         postfix.obj ../calc/postfix.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m calcPerform.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         calcPerform.obj ../calc/calcPerform.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m cvtFast.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         cvtFast.obj ../cvtFast/cvtFast.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m resourceLib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         resourceLib.obj ../cxxTemplates/resourceLib.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsSingletonMutex.obj ../cxxTemplates/epicsSingletonMutex.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m dbmf.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         dbmf.obj ../dbmf/dbmf.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m ellLib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         ellLib.obj ../ellLib/ellLib.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m ellSort.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         ellSort.obj ../ellLib/ellSort.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m envSubr.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         envSubr.obj ../env/envSubr.c
"Installing created executable ../../../../bin/windows-x64/bldEnvData.pl"
perl -CSD ../../../../bin/windows-x64/bldEnvData.pl  -t windows-x64 \
	-c msvc -s WIN32 ../../../../configure
Generating envData.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m envData.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         envData.obj envData.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m errlog.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         errlog.obj ../error/errlog.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m errSymLib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         errSymLib.obj ../error/errSymLib.c
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../error/errSymTbl.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m errSymTbl.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         errSymTbl.obj errSymTbl.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m fdmgr.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         fdmgr.obj ../fdmgr/fdmgr.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m fdManager.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         fdManager.obj ../fdmgr/fdManager.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m freeListLib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         freeListLib.obj ../freeList/freeListLib.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m gpHashLib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         gpHashLib.obj ../gpHash/gpHashLib.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m iocsh.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         iocsh.obj ../iocsh/iocsh.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m initHooks.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         initHooks.obj ../iocsh/initHooks.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m registry.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         registry.obj ../iocsh/registry.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m libComRegister.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         libComRegister.obj ../iocsh/libComRegister.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m iocLog.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         iocLog.obj ../log/iocLog.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m logClient.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         logClient.obj ../log/logClient.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m macCore.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         macCore.obj ../macLib/macCore.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m macEnv.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         macEnv.obj ../macLib/macEnv.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m macUtil.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         macUtil.obj ../macLib/macUtil.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m alarmString.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         alarmString.obj ../misc/alarmString.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m aToIPAddr.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         aToIPAddr.obj ../misc/aToIPAddr.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m adjustment.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         adjustment.obj ../misc/adjustment.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m cantProceed.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         cantProceed.obj ../misc/cantProceed.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsConvert.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsConvert.obj ../misc/epicsConvert.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsExit.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsExit.obj ../misc/epicsExit.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsStdlib.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsStdlib.obj ../misc/epicsStdlib.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsString.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsString.obj ../misc/epicsString.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m truncateFile.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         truncateFile.obj ../misc/truncateFile.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         ipAddrToAsciiAsynchronous.obj ../misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsUnitTest.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsUnitTest.obj ../misc/epicsUnitTest.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsThread.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsThread.obj ../osi/epicsThread.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsMutex.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsMutex.obj ../osi/epicsMutex.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsEvent.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsEvent.obj ../osi/epicsEvent.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsTime.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsTime.obj ../osi/epicsTime.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsMessageQueue.obj ../osi/epicsMessageQueue.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsMath.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsMath.obj ../osi/epicsMath.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsAtomicOSD.obj ../osi/os/default/epicsAtomicOSD.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsGeneralTime.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsGeneralTime.obj ../osi/epicsGeneralTime.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osiClockTime.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osiClockTime.obj ../osi/osiClockTime.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdSock.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdSock.obj ../osi/os/WIN32/osdSock.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdSockAddrReuse.obj ../osi/os/default/osdSockAddrReuse.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdSockUnsentCount.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdSockUnsentCount.obj ../osi/os/WIN32/osdSockUnsentCount.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osiSock.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osiSock.obj ../osi/osiSock.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m systemCallIntMech.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         systemCallIntMech.obj ../osi/os/WIN32/systemCallIntMech.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsSocketConvertErrnoToString.obj ../osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdAssert.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdAssert.obj ../osi/os/default/osdAssert.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdFindSymbol.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdFindSymbol.obj ../osi/os/WIN32/osdFindSymbol.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdInterrupt.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdInterrupt.obj ../osi/os/default/osdInterrupt.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdPoolStatus.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdPoolStatus.obj ../osi/os/WIN32/osdPoolStatus.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdSignal.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdSignal.obj ../osi/os/WIN32/osdSignal.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdEnv.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdEnv.obj ../osi/os/WIN32/osdEnv.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsReadline.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsReadline.obj ../osi/epicsReadline.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsTempFile.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsTempFile.obj ../osi/os/WIN32/epicsTempFile.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsStdio.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsStdio.obj ../osi/epicsStdio.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdStdio.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdStdio.obj ../osi/os/WIN32/osdStdio.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdThread.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdThread.obj ../osi/os/WIN32/osdThread.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdThreadExtra.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdThreadExtra.obj ../osi/os/WIN32/osdThreadExtra.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdThreadHooks.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdThreadHooks.obj ../osi/os/default/osdThreadHooks.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdMutex.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdMutex.obj ../osi/os/WIN32/osdMutex.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdSpin.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdSpin.obj ../osi/os/default/osdSpin.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdEvent.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdEvent.obj ../osi/os/WIN32/osdEvent.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdTime.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdTime.obj ../osi/os/WIN32/osdTime.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdMonotonic.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdMonotonic.obj ../osi/os/WIN32/osdMonotonic.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdProcess.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdProcess.obj ../osi/os/WIN32/osdProcess.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdNetIntf.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdNetIntf.obj ../osi/os/WIN32/osdNetIntf.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdMessageQueue.obj ../osi/os/default/osdMessageQueue.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdgetexec.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdgetexec.obj ../osi/os/WIN32/osdgetexec.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m devLibVME.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         devLibVME.obj ../osi/devLibVME.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m devLibVMEOSD.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         devLibVMEOSD.obj ../osi/os/default/devLibVMEOSD.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsStackTrace.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsStackTrace.obj ../osi/epicsStackTrace.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdBackTrace.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdBackTrace.obj ../osi/os/WIN32/osdBackTrace.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m osdFindAddr.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         osdFindAddr.obj ../osi/os/WIN32/osdFindAddr.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m poolJob.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         poolJob.obj ../pool/poolJob.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m threadPool.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         threadPool.obj ../pool/threadPool.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsRingPointer.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsRingPointer.obj ../ring/epicsRingPointer.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsRingBytes.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsRingBytes.obj ../ring/epicsRingBytes.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m taskwd.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         taskwd.obj ../taskwd/taskwd.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsTimer.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsTimer.obj ../timer/epicsTimer.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m timer.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         timer.obj ../timer/timer.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m timerQueue.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         timerQueue.obj ../timer/timerQueue.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m timerQueueActive.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         timerQueueActive.obj ../timer/timerQueueActive.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         timerQueueActiveMgr.obj ../timer/timerQueueActiveMgr.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m timerQueuePassive.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         timerQueuePassive.obj ../timer/timerQueuePassive.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl.obj ../yajl/yajl.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl_alloc.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl_alloc.obj ../yajl/yajl_alloc.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl_buf.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl_buf.obj ../yajl/yajl_buf.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl_encode.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl_encode.obj ../yajl/yajl_encode.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl_gen.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl_gen.obj ../yajl/yajl_gen.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl_lex.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl_lex.obj ../yajl/yajl_lex.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m yajl_parser.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         yajl_parser.obj ../yajl/yajl_parser.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m epicsGetopt.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         epicsGetopt.obj ../osi/os/WIN32/epicsGetopt.c
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m setThreadName.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         setThreadName.obj ../osi/os/WIN32/setThreadName.cpp
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/mkmf.pl  -m forceBadAllocException.d -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         forceBadAllocException.obj ../osi/os/WIN32/forceBadAllocException.cpp
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../yacc/closure.c
closure.c
C:\Epics\base-7.0.9\modules\libcom\src\yacc\defs.h(1): fatal error C1083: Cannot open include file: 'assert.h': No such file or directory
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I../osi/compiler/msvc -I../osi/compiler/default -I. -I../osi/os/WIN32 -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../flex/ccl.c
ccl.c
C:\Epics\base-7.0.9\modules\libcom\src\flex\flexdef.h(32): fatal error C1083: Cannot open include file: 'stdio.h': No such file or directory
"Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm"
"Expanding ../log/S99logServer@ to S99logServer"
perl -CSD C:/Epics/base-7.0.9/bin/windows-x64/expandVars.pl  -a windows-x64 -t ../../../.. -D INSTALL_BIN=C:/Epics/base-7.0.9/bin/windows-x64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="24"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="0"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="0"  ../log/S99logServer@ S99logServer
"Installing created executable ../../../../bin/windows-x64/S99logServer"
make[4]: Leaving directory 'C:/Epics/base-7.0.9/modules/libcom/src/O.windows-x64'
make[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'.  Stop.
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[3]: Leaving directory 'C:/Epics/base-7.0.9/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory 'C:/Epics/base-7.0.9/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
make[1]: Leaving directory 'C:/Epics/base-7.0.9/modules'
make: *** [configure/RULES_DIRS:85: modules.install] Error 2
RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
EPICS build problem Federico Galdenzi via Tech-talk
Re: EPICS build problem Federico Galdenzi via Tech-talk
Prev: Re: Handling Polling and CPU Bottleneck for Large Image Capture in areaDetector Kim, Kuktae via Tech-talk
Next: Compile StreamDevice with PCRE on windows Neidherr, Dennis Dr. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Next: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
ANJ, 29 Apr 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
