If you can't build test.c then re-run the visual studio installer and check that the "desktop development with c++" component isn't missing items - it might be easier to try reinstall/repair it
Freddie
> -----Original Message-----
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Freddie
> Akeroyd - STFC UKRI via Tech-talk
> Sent: 29 April 2025 11:49
> To: 'Federico Galdenzi' <galdenzi at roma2.infn.it>; tech-talk at aps.anl.gov
> Subject: RE: EPICS build problem
> Hi,
> Can you just try the following to check your compiler is working correctly
> From a new command window run vcvarsall.bat x64 which for me is
> running the command
> "C:\Program Files\Microsoft Visual
> Studio\2022\Enterprise\VC\Auxiliary\Build\vcvarsall.bat" x64
> But your visual studio may be a different version or in a different location. It
> should reply with something like
> ** Visual Studio 2022 Developer Command Prompt v17.11.5
> ** Copyright (c) 2022 Microsoft Corporation
> [vcvarsall.bat] Environment initialized for: 'x64'
> Now create a simple test.c file containing
> #include <stdio.h>
> int main(int argc, char* argv[])
> printf("Test\n");
> return 0;
> Now try and build this file with
> cl test.c
> which should generate output to screen like
> C:\Users> cl test.c
> Microsoft (R) C/C++ Optimizing Compiler Version 19.41.34123 for x64
> Copyright (C) Microsoft Corporation. All rights reserved.
> test.c
> Microsoft (R) Incremental Linker Version 14.41.34123.0 Copyright (C)
> /out:test.exe
> test.obj
> if that works try running the executable
> C:\Users> test.exe
> Test
> Regards,
> Freddie
> > From: Federico Galdenzi <galdenzi at roma2.infn.it>
> > Sent: 29 April 2025 10:05
> > To: tech-talk at aps.anl.gov
> > Cc: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>;
> > Rivers <rivers at cars.uchicago.edu>
> > Subject: Re: EPICS build problem
> > Dear Freddie and Mark, thanks again for your help. As you can see here
> > in the logs i still have the bug of not finding stdio.h and assert.h in my
> computer.
> > I know that this is basic but i cant' really find a solution.
> > Regards, Federico.
> > Il 2025-04-16 17:42 Freddie Akeroyd - STFC UKRI ha scritto:
> > > Hi,
> > > The windows.bat / win32.bat files just run vcvarsall.bat, set
> > > EPICS_HOST_ARCH and add perl to the PATH, so are just convenient
> > > shortcuts and not strictly necessary
> > > When vcvarsall.bat is run it needs an argument to tell it the build
> > > architecture, and this needs to match your intended EPICS_HOST_ARCH.
> > > So try
> > > vcvarsall.bat x64
> > > set EPICS_HOST_ARCH=windows-x64
> > > for a 64bit build. If you needed a 32bit built it would be:
> > > vcvarsall.bat x86
> > > set EPICS_HOST_ARCH=win32-x86
> > > Regards,
> > > Freddie
> > > Sent: 16 April 2025 14:18
> > > To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
> > > Cc: Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov
> > > Hi Freddie,
> > > I've followed this part of the tutorial:
> > > Download the distribution from e.g.
> > > https://urldefense.us/v3/__https://epics-
> controls.org/download/base/base-
> 7.0.4.1.tar.gz__;!!G_uCfscf7eWS!b1VOPd55aMpieZhLKuO5fB6xHdr4WQtS91
> bqVyiSoXDI-F_tOKheBmTAOnLr1yjNIzyHCSLQj88T6elXs4WxNO-
> mVLVqhKbCHqs$ .
> > > Unpack it into a work directory.
> > > Open a Windows command prompt and change into the directory you
> > > unpacked EPICS Base into.
> > > Note: The complete path of the current directory mustn’t contain any
> > > spaces or parentheses. If your working directory path does, you can
> > > do another cd into the same directory, replacing every path
> > > component containing spaces or parentheses with its Windows short
> > > path (that can be displayed with dir /x).
> > > Set the EPICS host architecture EPICS_HOST_ARCH (windows-x64 for
> > > 64bit builds, win32-x86 for 32bit builds).
> > > Run the vcvarsall.bat script of your installation (the exact path
> > > depends on the type and language of installation) to set the
> > > environment for your build.
> > > Run make (or gmake if using the version from Strawberry Perl).
> > > When i cd to my folder, and typed "where cl" it doesnt' return
> > > anything not even after i ran the vcvarsall.bat. I didnt' ran the
> > > windows.bat because it wasn't written.
> > > Should i do it directly from the folder?
> > > Il 2025-04-16 13:39 Freddie Akeroyd - STFC UKRI ha scritto:
> > >> Hi,
> > >> In the startup directory of epics there are two bat files "win32.bat"
> > >> and "windows.bat" - which did you use to setup the compiler path etc.
> > >> win32.bat choses the compiler for 32bit builds and windows.bat for
> > >> 64bit builds. Your EPICS_HOST_ARCH environment variable is set for
> > >> a 64bit builds, but the error message suggests your build may be
> > >> using the 32bit compiler instead as the linker cannot target x64.
> > >> If you type
> > >> where cl
> > >> do you see a path with x64 in it like
> Studio\2022\Enterprise\VC\Tools\MSVC\14.41.34120\bin\Hostx64\x64\cl.e
> > >> x
> > >> e
> > >> Or do you see x86 present instead?
> > >> Regards,
> > >> Freddie
> > >> Sent: 16 April 2025 08:15
> > >> To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>;
> > >> Cc: tech-talk at aps.anl.gov
> > >> Thanks in advance for the help. I made the log for make and also i
> > >> can tell that i'm following by letter the tutorial that i've linked
> > >> to download and build epic base. I've installed perl and make manually.
> > >> Best regards.
> > >> Il 2025-04-15 14:07 Freddie Akeroyd - STFC UKRI ha scritto:
> > >>> Hi,
> > >>> We'll need to see a bit more of your build log to see exactly
> > >>> which libraries it is having a problem with, can you please post
> > >>> the whole build log by doing something like
> > >>> make clean uninstall
> > >>> make > make.log 2>&1
> > >>> And posting make.log
> > >>> Thanks,
> > >>> Freddie
> > >>>> Federico Galdenzi via Tech-talk
> > >>>> Sent: 15 April 2025 12:36
> > >>>> Subject: EPICS build problem
> > >>>> Good morning all,
> > >>>> I have a problem for installing EPICS on my machine. I've
> > >>>> followed the instruction given in this site:
> > >>>> https://urldefense.us/v3/__https://docs.epics-
> > >>>> controls.org/en/latest/getting-started/installation-windows-
> plain.html__;!!G_uCfscf7eWS!a8JQwg02mRdcrkywW5dKHGcNsNeXLRf67b5
> > >>>> q5862JV6Ua7PGUqoY-
> > cZfs9LwLV3OMeJndOUxaevRC33Kk58OGeOCCW8$
> > >>>> but it seems that i'm missing something, because i get the "make"
> > >>>> fatal error
> > >>>> LNK1112: module machine type 'x86' conflicts with target machine
> > >>>> type 'x64'.
> > >>>> I'm kinda new to this world but i cant' manage to understand what
> > >>>> i'm doing wrong. It seems that i'm using 32 bit libraries on a 64
> > >>>> bit environment, but i'm using Visual Studio latests kit's for
> > >>>> developing in C++ in both 64 and
> > >>>> 32 bit.
> > >>>> What can i do?
- EPICS build problem Federico Galdenzi via Tech-talk
- RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
- Re: EPICS build problem Federico Galdenzi via Tech-talk
RE: Unable to mind .lib files after successfully compiling EPICS using mingw64 Freddie Akeroyd - STFC UKRI via Tech-talk
Re: Waveform to single ai (again) Dr. Simon Friederich via Tech-talk
<2025>
<2025>
