1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Some questions about CaLab (Dariush Hampai)
From: Dariush Hampai via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 23 Jun 2025 17:18:06 +0200
Hi Kathryn,
thank you for your answer. Yoyu're right (Labview on windows). However I don't see any process in Task Manager that can store all the PV informations.
In order to explain better, i Started the SoftDemo.vi, so all the PV presented are stored.
I stopped it and closed it.
Then I create a very simple VI (in attachment the front panel and the block diagram) in order to explain better which is my problem. As you can see, I tried to disconnect in two ways the PVs (by name and all togheter). However the PVs remain stored.
Dariush
Il 23/06/2025 16:52, Kathryn Baker - STFC UKRI via Tech-talk ha scritto:
Hi Dariush,
I may have been wrong with the caching aspect, but as I say a quick look at the LabVIEW code for CaLab Info has a case structure and feedback nodes which I'd say  are in keeping with a functional global variable (this is a LabVIEW VI of a specific type, the VI doesn't follow that style properly, but I'd say does much the same thing.) So what I think it is doing is asking for the information the first time it is called, and then keeping that information in memory and returning it - depending on how you are calling it. (Would need to the LabVIEW code to do more than make this as a random stab in the dark guess.) This is supposition based on minimal information. But that might only be the case if the IOC is actually stopped, otherwise, if the IOC is running the PVs will be there, you can't stop or disconnect a PV at the IOC side easily from the LabVIEW side.
(For the experts, yes, I'm aware of the DIS fields, but I'm not certain the use case here is involving them, and they may be an additional complexity that isn't needed.)
CaLab is certainly the option I've found best when integrating on the LabVIEW side, but you do need a reasonable understanding of what each side is expecting and how they behave to be able to get the best results.
Please note, I have assumed that LabVIEW is running on a Windows system rather than the Linux system, which is again something that would make a difference to how things might be interacting.
So starting CaLabSoftIOC.vi will spawn the IOC as a separate process, that process knows nothing about LabVIEW, it will just run on the same computer that LabVIEW was running on all on it's own. Check out the task manager, you will see it in the list. So simply stopping LabVIEW won't stop the IOC. I'm intrigued that it survived a restart of the computer though. However, it would restart as soon as you start the VI, so it might be worth trying that again and checking in task manager before starting the IOC.
Regarding the architecture, you need to run the version that matches the OS you are on, as there are DLLs underneath which care about that.
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room:	+39.06.9403.5248
Lab.:	+39.06.9403.2286
Mob.:	+39.06.9403.8025
Fax.:	+39.06.9403.2597
Re: Some questions about CaLab (Dariush Hampai) Kathryn Baker - STFC UKRI via Tech-talk
Re: Some questions about CaLab (Dariush Hampai) Carsten Winkler via Tech-talk
Re: Some questions about CaLab (Dariush Hampai) Dariush Hampai via Tech-talk
Prev: areaDetector/asynPortDriver order of parameter initialization Irie Railton - STFC UKRI via Tech-talk
Next: RE: areaDetector/asynPortDriver order of parameter initialization Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: Some questions about CaLab (Dariush Hampai) Kathryn Baker - STFC UKRI via Tech-talk
Next: Re: Some questions about CaLab (Dariush Hampai) Kathryn Baker - STFC UKRI via Tech-talk
ANJ, 23 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
