1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Re: Problem with drvAsynIPPortConfigure
From: Dariush Hampai via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 22 Sep 2025 18:52:23 +0200
Hi Mark
Hi Community
thank you for your answer... not i works.
However, I don't understand why it works withe the three IOCs already done (and running...)
Thanks
Dariush
Il 19/09/2025 14:08, Mark Rivers ha scritto:
Hi Dariush,
Both Mark Engbretson  and Ralph Lange have explained what the problem is, but perhaps you did not understand.
You need to change your st.cmd so that these lines to near the top.  They must come before any of the asyn commands.
dbLoadDatabase "dbd/mdrive_1IOC.dbd"
mdrive_1IOC_registerRecordDeviceDriver pdbbase
So your st.cmd should look like this:
#!../../bin/linux-x86_64/mdrive_1IOC
< envPaths
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC"
epicsEnvSet ("STREAM_PROTOCOL_PATH", "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/db")
epicsEnvSet ("PORT_mdrive_x", "ip_x")
#X Axis
drvAsynIPPortConfigure(ip_x, "100.100.0.23:503")
asynOctetSetInputEos(ip_x,0,"\n\r")
asynOctetSetOutputEos(ip_x,0,"\n\r")
asynSetTraceMask(ip_x,-1,0x9);
asynSetTraceIOMask(ip_x,-1,0x2)
## Load record instances
#dbLoadRecords("db/mdrive_1IOC.db","user=xlabsrv2")
dbLoadTemplate("db/mdrive_1IOC.val")
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC"
iocInit
From: Dariush Hampai <dariush.hampai at lnf.infn.it>
Sent: Friday, September 19, 2025 3:03 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Mark Rivers <rivers at cars.uchicago.edu>
Hi Community,
I didn't write all the codes that are automatically generates by makeAppBase.pl application. By the way, I'll report below all the infos:
1) mdrive_1IOC/src/Makefile
# SPDX-FileCopyrightText: 2003 Argonne National Laboratory
# SPDX-License-Identifier: EPICS
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC application
PROD_IOC = mdrive_1IOC
# mdrive_1IOC.dbd will be created and installed
DBD += mdrive_1IOC.dbd
# mdrive_1IOC.dbd will be made up from these files:
mdrive_1IOC_DBD += base.dbd
# Include dbd files from all support applications:
#mdrive_1IOC_DBD += xxx.dbd
mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_DBD += drvAsynIPPort.dbd
mdrive_1IOC_DBD += stream-base.dbd
# Add all the support libraries needed by this IOC
#mdrive_1IOC_LIBS += xxx
mdrive_1IOC_LIBS += stream
mdrive_1IOC_LIBS += asyn
# mdrive_1IOC_registerRecordDeviceDriver.cpp derives from mdrive_1IOC.dbd
mdrive_1IOC_SRCS += mdrive_1IOC_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
mdrive_1IOC_SRCS_DEFAULT += mdrive_1IOCMain.cpp
mdrive_1IOC_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#mdrive_1IOC_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Finally link to the EPICS Base libraries
mdrive_1IOC_LIBS += $(EPICS_BASE_IOC_LIBS)
2) in st.cmd file
#- SPDX-FileCopyrightText: 2003 Argonne National Laboratory
#- SPDX-License-Identifier: EPICS
#- You may have to change mdrive_1IOC to something else
#- everywhere it appears in this file
< envPaths
cd "${TOP}"
epicsEnvSet ("STREAM_PROTOCOL_PATH", "${TOP}/db")
#X Axis
drvAsynIPPortConfigure($(PORT_mdrive_x), "100.100.0.23:503")
asynOctetSetInputEos($(PORT_mdrive_x),0,"\n\r")
asynOctetSetOutputEos($(PORT_mdrive_x),0,"\n\r")
asynSetTraceMask($(PORT_mdrive_x),-1,0x9);
asynSetTraceIOMask($(PORT_mdrive_x),-1,0x2)
cd "${TOP}/iocBoot/${IOC}"
iocInit
## Start any sequence programs
#seq sncxxx,"user=xlabsrv2"
3) "make all clean"
[xlabsrv2@xlabsrv2 mdrive_1IOC]$ make clean all
make -C ./configure clean
make[1]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/configure»
rm -rf O.linux-x86_64 O.Common
make[1]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/configure»
make -C ./mdrive_1IOCApp clean
make[1]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp»
make -C ./src clean
make[2]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/src»
make[2]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/src»
make -C ./Db clean
make[2]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/Db»
make[2]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/Db»
make[1]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp»
make -C ./iocBoot clean
make[1]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot»
make -C ./iocmdrive_1IOC clean
make[2]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC»
rm -f cdCommands envPaths dllPath.bat relPaths.sh
make[2]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC»
make[1]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot»
make -C ./configure install
perl -CSD /home/xlabsrv2/epics/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/configure/O.linux-x86_64»
perl -CSD /home/xlabsrv2/epics/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/configure/O.linux-x86_64»
make -C ./mdrive_1IOCApp install
make -C ./src install
perl -CSD /home/xlabsrv2/epics/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/src/O.linux-x86_64»
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/include   -I/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/include -I/home/xlabsrv2/epics/include/compiler/gcc -I/home/xlabsrv2/epics/include/os/Linux -I/home/xlabsrv2/epics/include        -MM -MF mdrive_1IOCMain.d  ../mdrive_1IOCMain.cpp
Creating dbd file mdrive_1IOC.dbd
perl -CSD /home/xlabsrv2/epics/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/dbd -I/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/dbd -I/home/xlabsrv2/epics/dbd -o mdrive_1IOC.dbd base.dbd asyn.dbd drvAsynIPPort.dbd stream-base.dbd
perl -CSD /home/xlabsrv2/epics/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/dbd -I/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/dbd -I/home/xlabsrv2/epics/dbd    -o mdrive_1IOC_registerRecordDeviceDriver.cpp \
            ../O.Common/mdrive_1IOC.dbd mdrive_1IOC_registerRecordDeviceDriver /home/xlabsrv2/epics/IOCs/mdrive_1IOC
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/include   -I/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/include -I/home/xlabsrv2/epics/include/compiler/gcc -I/home/xlabsrv2/epics/include/os/Linux -I/home/xlabsrv2/epics/include        -MM -MF mdrive_1IOC_registerRecordDeviceDriver.d  mdrive_1IOC_registerRecordDeviceDriver.cpp
Installing created dbd file ../../../dbd/mdrive_1IOC.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/include   -I/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/include -I/home/xlabsrv2/epics/include/compiler/gcc -I/home/xlabsrv2/epics/include/os/Linux -I/home/xlabsrv2/epics/include        -c mdrive_1IOC_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/include   -I/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/include -I/home/xlabsrv2/epics/include/compiler/gcc -I/home/xlabsrv2/epics/include/os/Linux -I/home/xlabsrv2/epics/include        -c ../mdrive_1IOCMain.cpp
/usr/bin/g++ -o mdrive_1IOC  -L/home/xlabsrv2/epics/IOCs/mdrive_1IOC/lib/linux-x86_64 -L/home/xlabsrv2/epics/lib/linux-x86_64 -L/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/lib/linux-x86_64 -L/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/lib/linux-x86_64 -Wl,-rpath,/home/xlabsrv2/epics/IOCs/mdrive_1IOC/lib/linux-x86_64 -Wl,-rpath,/home/xlabsrv2/epics/lib/linux-x86_64 -Wl,-rpath,/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24/lib/linux-x86_64 -Wl,-rpath,/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2/lib/linux-x86_64          -rdynamic -m64         mdrive_1IOC_registerRecordDeviceDriver.o mdrive_1IOCMain.o    -lstream -lasyn -ldbRecStd -ldbCore -lca -lCom
Installing created executable ../../../bin/linux-x86_64/mdrive_1IOC
make[3]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/src/O.linux-x86_64»
make -C ./Db install
mkdir -p O.Common
make[3]: ingresso nella directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/Db/O.linux-x86_64»
make[3]: Nessuna operazione da eseguire per «install».
make[3]: uscita dalla directory «/home/xlabsrv2/epics/IOCs/mdrive_1IOC/mdrive_1IOCApp/Db/O.linux-x86_64»
make -C ./iocBoot install
make -C ./iocmdrive_1IOC install
perl -CSD /home/xlabsrv2/epics/bin/linux-x86_64/convertRelease.pl -t /home/xlabsrv2/epics/IOCs/mdrive_1IOC envPaths
4) "./st.cmd"
[xlabsrv2@xlabsrv2 iocmdrive_1IOC]$ ./st.cmd
< envPaths
epicsEnvSet("IOC","iocmdrive_1IOC")
epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/mdrive_1IOC")
epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support")
epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2")
epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24")
epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
#X Axis
ERROR st.cmd line 36: Command drvAsynIPPortConfigure not found.
ERROR st.cmd line 37: Command asynOctetSetInputEos not found.
ERROR st.cmd line 38: Command asynOctetSetOutputEos not found.
ERROR st.cmd line 40: Command asynSetTraceMask not found.
ERROR st.cmd line 41: Command asynSetTraceIOMask not found.
iocInit
Starting iocInit
## EPICS R7.0.8.2-DEV
## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
## Rev. Date Git: 2025-02-05 10:16:16 -0600
2025/09/19 09:56:08.550149 _main_ Cannot find a bus named 'ip_x' for 'mdrive_x:model'
2025/09/19 09:56:08.550225 _main_ mdrive_x:model: Can't attach to bus ip_x 0
2025/09/19 09:56:08.550243 _main_ mdrive_x:model: Record initialization failed
5) "epics> help"
#               ClockTime_Report                asDumpHash      asInit
asSetFilename   asSetSubstitutions              ascar           asdbdump
asphag          aspmem          asprules        aspuag          astac
asynAutoConnect asynEnable      asynInterposeDelay
asynInterposeEcho               asynInterposeEosConfig
asynInterposeFlushConfig        asynOctetConnect
asynOctetDisconnect             asynOctetFlush  asynOctetGetInputEos
asynOctetGetOutputEos           asynOctetRead   asynOctetSetInputEos
asynOctetSetOutputEos           asynOctetWrite  asynOctetWriteRead
asynRegisterTimeStampSource     asynReport      asynSetAutoConnectTimeout
asynSetMinTimerPeriod           asynSetOption   asynSetQueueLockPortTimeout
asynSetTraceFile                asynSetTraceIOMask
asynSetTraceIOTruncateSize      asynSetTraceInfoMask
asynSetTraceMask                asynShowOption  asynUnregisterTimeStampSource
asynWaitConnect callbackParallelThreads         callbackQueueShow
callbackSetQueueSize            casr            cd              coreRelease
date            dbCreateAlias   dbDumpBreaktable                dbDumpDevice
dbDumpDriver    dbDumpField     dbDumpFunction  dbDumpLink      dbDumpMenu
dbDumpPath      dbDumpRecord    dbDumpRecordType
dbDumpRegistrar dbDumpVariable  dbLoadDatabase  dbLoadRecords   dbLoadTemplate
dbLockShowLocked                dbNotifyDump    dbPutAttribute  dbPvdDump
dbPvdTableSize  dbReportDeviceConfig            dbStateClear    dbStateCreate
dbStateSet      dbStateShow     dbStateShowAll  dba             dbap
dbb             dbc             dbcar           dbd             dbel
dbgf            dbgrep          dbhcr           dbior           dbjlr
dbl             dbla            dbli            dblsr           dbnr
dbp             dbpf            dbpr            dbs             dbsr
dbstat          dbtgf           dbtpf           dbtpn           dbtr
drvAsynIPPortConfigure          drvAsynIPServerPortConfigure    echo
eltc            epicsEnvSet     epicsEnvShow    epicsEnvUnset
epicsMutexShowAll               epicsParamShow  epicsPrtEnvParams
epicsThreadResume               epicsThreadShow epicsThreadShowAll
epicsThreadSleep                errlog          errlogInit      errlogInit2
exit            generalTimeReport               gft             help
installLastResortEventProvider  iocBuild        iocInit         iocLogInit
iocLogPrefix    iocLogShow      iocPause        iocRun          iocshCmd
iocshLoad       iocshRun        mdrive_1IOC_registerRecordDeviceDriver
on              pft             postEvent       pwd
registerAllRecordDeviceDrivers  registryDeviceSupportFind
registryDriverSupportFind       registryDump    registryFunctionFind
registryRecordTypeFind          scanOnceQueueShow
scanOnceSetQueueSize            scanpel         scanpiol        scanppl
setIocLogDisable                streamReinit    streamReload
streamReportRecord              streamSetLogfile                taskwdShow
tpn             var
Il 19/09/2025 03:35, Ralph Lange via Tech-talk ha scritto:
I think you have the order of things in the startup file wrong.
The block
loads the dbd file and registers all Record, Device and Driver Support modules with EPICS. This includes the registration of iocShell commands.
Before this block is run, the iocShell does not know the asyn-related commands.
Cheers,
~Ralph
-- ************************************ Dr. Dariush Hampai, PhD INFN - LNF X-Lab Frascati Via E. Fermi, 54 (ex 40) I-00044 Frascati (RM) Italy Mail Address: XLab-Frascati LNF-INFN Casella Postale 13 Frascati (RM) Italy Room: +39.06.9403.5248 Lab.: +39.06.9403.2286 Mob.: +39.06.9403.8025 Fax.: +39.06.9403.2597 ************************************
INFN - LNF
X-Lab Frascati
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
RE: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Re: Problem with drvAsynIPPortConfigure Ralph Lange via Tech-talk
Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Re: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
Prev: EPICS Support for Pfeiffer Primsaplus QMG 220 Heinz Junkes (FHI) via Tech-talk
Next: RE: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
ANJ, 22 Sep 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
