Subject: |
Re: Recommended setting for XyCom 566 Analog input module? |
[email protected] (Ned Arnold) |
Date: |
Mon, 8 May 1995 09:38:14 -0500 |
> Hello All,
> Here's a novice question. I'm starting to set up the hardware for
> our beamline (all dealings with EPICS so far have been theoretical(!)), and
> so I'm trying to interface my first module, the XVME-566.
> Naturally, there are numerous jumpers and options. CSR addresses,
> data RAM addresses, interrupt levels etc. Quite a jumble for the first
> module.
> Can anyone give me a quick, simple, tutorial on what the appropriate
> values should be, and how these might relate to the DCT VME parameters
> Card/Signal/Parameter?
I guess I'll post this to tech-talk, others may be interested ...
The XYCOM 566 drivers determine what input mode you selected by expecting the
following addresses ...
XYCOM MODE CSR Addr Data RAM Addr
Single ended A16: 0x6000 A24: 0x000000 (card 0)
(scanned) A16: 0x6400 A24: 0x010000 (card 1)
etc
Differential A16: 0x7000 A24: 0x040000 (card 0)
(scanned) A16: 0x7400 A24: 0x050000 (card 1)
etc
Differential A16: 0xe000 A24: 0x0c0000 (card 0)
(Latched,requires A16: 0xe400 A24: 0x0d0000 (card 1)
a ext trigger) etc
Waveform Mode A16: 0x9000 A24: 0x080000 (card 0)
(Waveform A16: 0x9400 A24: 0x090000 (card 1)
Record) etc
The Device Type selected in DCT (SE Scanned, Dif Scanned, Dif Latched) must
match the way you addressed the card. Four cards are supported for each
type. "Signal" goes from 0 to 15 (differential) or 0-31 (SE). Parameter is
ignored.
Interrupt Level 5 will work (I believe).
The input jumpers for each type are a real challenge and left as an
exercise for the user (I don't have a board handy, sorry). However, the
above info will stop you from having to grep through modules_types.h, like
some of us have had to do !!
One more thing ... Don't blame me, I didn't write it !!!!
Ned
Re: VME to CAMAC interface module watson
Re: Recommended setting for XyCom 566 Analog input module? Andrew Johnson
<1995>
2025
2026
Recommended setting for XyCom 566 Analog input module? 415
<1995>
2025
2026
