1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems with solaris-sparc-gnu
To: <[email protected]>, <[email protected]>
Cc: <[email protected]>
Date: Wed, 17 Dec 2003 23:38:27 -0600
A couple of weeks ago I reported:
> I'm having some problems building EPICS 3.14 stuff on
> solaris-sparc-gnu.  I have built base 3.14.4 with no
> problems.  I have also built the EPICS example application,
> including the snc example, and the soft IOC works OK.
> The problems I'm having are:
> - An error linking the mpf2-4 test programs.  A C++ routine
> (Tcp::connect) which should definitely exist in the libmpf.so
> library is not being found at link time.
This problem is now fixed by upgrading gcc from 2.95.3 to 3.3.2.
> - I have built the 3.14 versions of the extensions ezca,
> EzcaScan and ezcaIDL with no problems.  However, when I try
> to use the resulting ezcaIDL.so from IDL on Solaris to do
> channel access it gives a bus error and crashes.
This problem was solved by setting LD_LIBRARY_PATH to point to the new extensions library.  It was (mistakenly) pointing to the old extensions library directory.
Thanks to Tim Graber, Marty Kraimer, Andrew Johnson and Ben-Chin Cha in solving this.
Prev: cross-compiling base3.14.0alpha2 error Zhao Zhuo
Next: Re: cross-compiling base3.14.0alpha2 error Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problems with solaris-sparc-gnu Mark Rivers
Next: [Fwd: Re: Tornado 2.2, cross-compiling woes] Marty Kraimer
