Kate Feng wrote:
> I agree with you that one should enable the posted write by default.
> However, it could be disabled, which means the address
> pipelining on the UniverseII could be disabled as well on the Mvme5500.
> I thought the origianl issue is "to disable the address pipelinig".
> It looks like you have a reason to disable the posted write
> for the NI VME-MXI-1. The trad off is to sacrifice the bandwidth
> of the VME bus. However, I do not know if the decrease is
> significant for your application. I hope this helps.
I ran a short test, which showed a decrease of 33% in
performance for the posted-write disabled mode. It might not be worse
than the VMEchip2 that was used on the MVME167, which is in
your existing system. I do not have the datasheet for the
VMEchip2. I guess it does not provide address pipeling,
which explained why it worked fine with the MXI-1.
Again, hoping this helps. -- Kate
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Eric Bjorklund
- mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Kate Feng
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modern VME CPU modules) Andrew Johnson
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Kate Feng
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVME CPU modules) Andrew Johnson
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Kate Feng
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPU modules) Andrew Johnson
- Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Kate Feng
Job opening at APS John Maclean
<2004>
2025
2026
<2004>
2025
2026
