1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about Channel Archiver
To: huangsong <[email protected]>
Cc: [email protected]
Date: Thu, 23 Jun 2005 12:22:04 +0200
huangsong wrote:
Thanks for reply.
The 'data'command print the correct time.
My Host is running Linux 9.0, TZ isn't defined. After I defined it, there has no effect for the problem.
Yes, EPICS_TS_MIN_WEST is used to convert the timestamps of the exported data.
But what will effect the start time?
Since you are running a slightly old version of the ChannelArchiver I unfortunately cannot reproduce your problem, but:
The ChannelArchiver uses (and used to utilize) the functions provided by the EPICS-Base to do the conversion of timestamps
* locattime <-> UTC (or whatever EPICS's base-timezone is)
* and in the older versions even to convert timestamp <-> string
Nevertheless, in your case, it looks like the timestamp you provide on the command-line is always taken as a UTC-timestamp.
This is definitely not the expected behaviour! And I don't have the sources of ChannelArchiver 1.10.2 at hand to look/try it.
I just found an old HP-UX-binary of ArchiveExport (version 1.9.2) compiled against EPICS-base 3.13.5 and while playing with the environment (setting EPICS_TS_MIN_WEST and/or TZ to different values) unfortunately does not show the behaviour you observe!
Indeed it behaves well - it uses EPICS_TS_MIN_WEST to parse the command-line-arguments and to print the timestamps for the output. So the timestamps printed are always in the range of what I specified on the command-line. TZ has no influence at all.
EPICS_TS_MIN_WEST=-480
./hp700-1.9.2/ArchiveExport -start '01/06/04 02:00:00' -end '01/06/04 02:01:00' directory MDIZ3T5G:current
Time MDIZ3T5G:current [mA]
01/06/2004 01:59:59.144578069 4.882
01/06/2004 02:00:09.147168847 4.860
01/06/2004 02:00:18.947919171 4.840
01/06/2004 02:00:29.101599783 3.639
01/06/2004 02:00:39.189630846 3.475
01/06/2004 02:00:48.956558186 2.622
01/06/2004 02:00:59.000995515 2.352
01/06/2004 02:01:09.201892629 1.838
01/06/2004 01:59:59.797524861 -0.152
01/06/2004 02:00:09.696648741 -0.150
01/06/2004 02:00:19.558158965 -0.153
01/06/2004 02:00:29.772687281 -0.152
01/06/2004 02:00:39.739121581 -0.154
01/06/2004 02:00:49.566553625 -0.154
01/06/2004 02:00:59.764922136 -0.154
01/06/2004 02:01:09.797810589 -0.156
So, sorry, no help actually, just a description of how it "should" behave...
Thomas
______________________________________________________________________
/homas.Birke @ bessy.de
BESSY                                           Tel: +49 30 6392 4934
Albert Einstein Straße 15                       Fax: +49 30 6392 4859
12489 Berlin
Germany
question about Channel Archiver huangsong
Re: question about Channel Archiver Ralph Lange
Re: question about Channel Archiver huangsong
Prev: Re: question about Channel Archiver huangsong
Next: Re: question about Channel Archiver Peter Groszkowski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
