1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream protocol configuration
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Thu, 13 Dec 2007 13:40:19 -0800
> No. Just use  @init {readRegister;}
> Example:
> readRegister { out "\$1"; in "%i";}
> writeRegister { ...  @init {readRegister;} }
This is interesting. It means that writeRegister and readRegister must
have the same parameters and in the same order. readRegister($1, $2) for
example would seem more intuitive, besides I could also do
readRegister($2,$1), or readRegister(23,$3), etc.
I looked at the aai record.
Why is the aai record not compiled in?
I suspect it is because R3.13 did not include it in its epics bases, is
this the case?
I noticed that my IN directive for a protocol is hitting a limit.
I did not investigate this problem in depth.
But I am faced with the situation where I have something like
in "%*x,%*f,%*i,%*X,%*f,%*f,%*f,%*f,%*f,%*f,%*f,%*f,%*f, (a few
more ;-),%*f,%*f" ;
If the IN directive is too long (or there are too many converter
matching), then the program complains and do not work.
Is there a "length" and/or "number" limit(s) on the directives?
I use a device with crc/checksum checking. the converter works very
well. But the communication is flaky. So I get crc errors for 20% of my
messages. As a result my IOC terminal is flooded with asyn/stream error
messages. Is there a way to disable those globally? or locally at the
protocol level?
Before implementing the aai record, I tried with several ai configured
as I/O intr scanned records.
1/ For one of my devices, I have the reply from the device broken in two
segments and the matching by the I/O intr ai is not working.
The matching would clearly work on the complete reply.
The situation I am facing is similar to
the value is in the first reply segment, but I need to check the crc
which is in the other segment of the reply.
What the pollTimeout parameter to control just that?
2/ I have another device with whom I can do 1 ai trigger record ( with
the OUT directive) and several ai records configured as I/O intr. I
noticed that the trigger record times out (STAT = TIMEOUT right after
all the @init complete) if too many I/O intr records are attached.
Is that expected? Do I/O intr record lock the asyn interface?
Finally (and this is on my wish list), I would like to have protocol
directives able to communicate on different asyn interfaces.
For example, I would like to OUT on an asyn file interface for debugging
purpose or IN on again a another asyn file interface for the init value.
Right now, I can do that but it requires each time rewriting the asyn
interface code. So allowing for the asyn port/interface to be set in the
protocol would be welcome.
Cheers,
Emmanuel
Re: Stream protocol configuration Dirk Zimoch
writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream converter Emmanuel Mayssat
Stream protocol configuration Emmanuel Mayssat
Re: Stream protocol configuration Emmanuel Mayssat
Prev: Build of edm 1-11-0zi errors Margaret Smith
Next: First announcement on the next EPICS collaboration meeting /EPICS seminar SQLiu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream protocol configuration Dirk Zimoch
Next: Re: Stream protocol configuration Dirk Zimoch
