1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream protocol configuration
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Fri, 07 Dec 2007 14:09:45 +0100
Emmanuel Mayssat wrote:
On Thu, 2007-12-06 at 10:02 +0100, Dirk Zimoch wrote:
readSomething { maxInput=10; out "..."; in "..."; }
writeSomething {
	maxInput=25;
         out "...";
	@init {readSomething;}
The @init handler uses the setting maxInput=25.
Obviously there is something wrong with the above. It is actually the situation I am facing where my protocol has no terminator and read and write protocols are fundamentally different.
Some of the protocols I have to program are also a bit more complex than
write-once and read-once. They are acknowledgments and some other
features involved.
What exactly do you need to do? Please describe the desired protocol.
In the current implementation, a protocol (including all its handlers) has only one set of settings. It is not possible to change settings at run time.
That would be a nice addition and would be more intuitive. As I mentioned earlier I was able to find work-arounds for the issues I have. BTW, I found streamDevice to work intuitively and as-is for 95% of my drivers. I love it!
2/ Parameter passing
I am able to refer to another protocol entry in the exception handler
Example:
writeRegister {
  @init {
     readRegister;
You can consider this a two-stage macro substitution. First readRegister in the @init handler is replaced with all the commands (but NOT the settings) of the readRegister protocol. Then all parameters in the writeRegister protocol and all its handlers are replaced with the values passed in the link, including those parameters which came originally from the readRegister protocol.
In the @init readRegister($1); readRegister $1; did not work for me. Are you saying I should try again? Ok ...
No. Just use @init {readRegister;}
Example:
readRegister { out "\$1"; in "%i";}
writeRegister { ...  @init {readRegister;} }
This is the same as:
writeRegister { ...  @init {out "\$1"; in "%i";} }
The word readRegister is replaced by the commands of the referenced protocol.
field (OUT, "@file writeRegister(XXX) bus")
Now "\$1" is replaced with "XXX", resulting to
writeRegister { ...  @init {out "XXX"; in "%i";} }
Thus, at initialization, the protocol will do: {out "XXX"; in "%i"; }.
Emmanuel
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: Stream protocol configuration Emmanuel Mayssat
writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream converter Emmanuel Mayssat
Re: Stream protocol configuration Dirk Zimoch
Prev: Re: EPICS in Debian 4.0 Linux Umashankar Panda
Next: problem about cross-compiling vxworks for vxWorks-pentium under windows xp marco_hair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream protocol configuration Emmanuel Mayssat
Next: Re: Stream protocol configuration Emmanuel Mayssat
