1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm font file
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Tue, 15 Apr 2008 20:55:42 -0400
it looks like a local vs. remote X setup issue. xlsfonts queries the X server. From the console of machineA (something like display :0) xlsfont will list fonts on machineA's X server.
Now from the console of machineB, although you remote start something on machineA, your X client will be served by machineB X server who will answer font requests
In recap, you might try a shorter list of fonts that are common to both machines.
Matthieu
I think your fonts are served by your X server.
although you might ssh -Y/X, your display still is a client of your local server.
Emmanuel Mayssat wrote:
Errata: (once more!) not from a RH8.0 machine but from a Fedora 8
machine. Edm through ssh actually works from a RH8 machine.
E
On Tue, 2008-04-15 at 17:28 -0700, Emmanuel Mayssat wrote:
Update:
If I ssh from a machine that has the same OS (fedora core 4), the error
disappear!!! When I ssh from a RH8.0 machine, edm report the Font init
failed - abort error.
Huh?!?!?
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
edm font file Emmanuel Mayssat
Re: edm font file Emmanuel Mayssat
Re: edm font file J. Lewis Muir
Prev: Re: edm font file Emmanuel Mayssat
Next: autosave issues Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
