On Friday 19 December 2008 02:57:29 Shi HaoLi wrote:
> Cexp>dbgf ("R4IBT04:CISet")
> DBR_DOUBLE: 0
> 0x00000000 (0)
> Cexp>dbtr("R4IBT04:CISet")
> ACKS: INVALID ACKT: YES ADEL: 0 ALST: 0
> filename="../recGbl.c" line number=88
> AOFF: -5.01 ASG: ASLO: 1.525902e-04 BKPT: 0x00
> PV: R4IBT04:CISet dbtr(dbProcess)
> DESC: analog output record DISA: 0 DISP: 0
> DISS: NO_ALARM DISV: 1 DOL:CONSTANT 0.000000000000000e+00
> DRVH: 0 DRVL: 0 DTYP: PSC EGU: amps
> EGUF: 0 EGUL: 0 EOFF: 0 ESLO: 0
> EVNT: 0 FLNK:CONSTANT 0 HHSV: NO_ALARM HIGH: 0
> HIHI: 5 HOPR: 4.545455 HSV: NO_ALARM HYST: 0
> INIT: 0 IVOA: Continue normally IVOV: 0
> LALM: 0 LBRK: 0 LCNT: 0 LINR: NO
> CONVERSION LLSV: NO_ALARM LOLO: -5 LOPR: -4.545455 LOW:
> 0 LSV: NO_ALARM MDEL: 0 MLST: 0 NAME:
> R4IBT04:CISet NSEV: NO_ALARM NSTA: NO_ALARM OIF: Full
> OMOD: 0 OMSL: supervisory ORAW: 32833 ORBV: 1062 OROC: 0
> OUT:VME_IO #C1 S0 @SPT OVAL: 0 PACT: 0 PHAS: 0
> PINI: NO PREC: 3 PRIO: LOW PROC: 0
> PUTF: 0 PVAL: 0 RBV: 1062 ROFF: 0
> RPRO: 0 RVAL: 32833 SCAN: Passive SDIS:CONSTANT
> 0.000000000000000e+00 SEVR: INVALID
> SIML:CONSTANT 0.000000000000000e+00 SIMM: NO SIMS: NO_ALARM
> SIOL:CONSTANT 0.000000000000000e+00 STAT: READ TPRO: 0
> TSE: 0 TSEL:CONSTANT UDF: 1 VAL: 0
> 0x00000000 (0)
> Cexp>dbpf ("R4IBT04:CISet", "2.0")
> 0xffffffff (-1)
> filename="../dbTest.c" line number=365
> dbPutField error
> I guess something is wrong when the record "R4IBT04:CISet" calls device
> support write_ao which calls driver support, I don't know how to solve it.
> thank you again!
The above errors are very similar to the previous one, in that I believe they
are caused by the PSC device support's write_ao() routine returning -1. Both
your dbtr() and dbpf() commands cause the record to process resulting in the
device support being called; if write_ao() returns any non-zero value it will
be passed back up the call tree and eventually result in they messages that
you are seeing. What that return value means is a question you'll have to
ask the person who wrote the device support.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- ao record downloading error Shi HaoLi
- Re: ao record downloading error Andrew Johnson
- Re: ao record downloading error Shi HaoLi
Units request for stringin records John Faucett
<2008>
2025
2026
Firewire (IEEE 1394) support for areaDetector Pedersen, UK (Ulrik)
<2008>
2025
2026
