That's what I suspected. I don't think that is right. I would uninstall both packages, make sure those files are gone and reinstall.
Sent: Wed 9/23/2009 11:08 PM
To: Mark Rivers
Cc: Matthieu Bec; [email protected]
Subject: Re: alarm handler on base 3-14-11
/usr/lib/libcurses.so seems to be a link to /usr/lib64/libncurses.so.5.5
Mark Rivers wrote:
> Do
> ls -l /usr/lib64/*curse*
> and see what the real files are, what are soft links, etc.
> ________________________________
> From: [email protected] on behalf of Patrick Thomas
> Sent: Wed 9/23/2009 10:54 PM
> To: Matthieu Bec
> Cc: [email protected]
> It said:
> /sbin/ldconfig: libraries libcurses.so and libncurses.so.5.5 in directory /usr/lib have same soname but different type.
> Matthieu Bec wrote:
>> Hi Patrick,
>> try running ldconfig (as root), that might help fix missing softlink etc.
>> and then rebuild as normal
>> On 09/23/09 23:38, Patrick Thomas wrote:
>>> I'm not sure. I see the path to /usr/lib64 being used by make, so I'm
>>> confused why it wouldn't find it there.
>>> /usr/bin/g++ -o alh
>>> -L/users/thomas/epics/base/base-3-14-11/lib/linux-x86_64 -L/usr/lib64
>>> -Wl,-rpath,/users/thomas/epics/base/base-3-14-11/lib/linux-x86_64
>>> -Wl,-rpath,/usr/lib64 -m64 alCA.o acknowledge.o alAudio.o alarm.o
>>> alCaCommon.o alConfig.o alFilter.o alLib.o alLog.o alView.o alh.o
>>> awAct.o awAlh.o awEdit.o awView.o axArea.o axRunW.o axSubW.o browser.o
>>> current.o dialog.o file.o force.o guidance.o heartbeat.o help.o line.o
>>> mask.o process.o property.o scroll.o showmask.o sllLib.o beepSevr.o
>>> noAck.o -lca -lCom -lXmu -lXm -lXt -lX11 -lXp -lpthread -lreadline
>>> -lncurses -lm -lrt -ldl -lgcc
>>> /usr/bin/ld: cannot find -lncurses
>>> collect2: ld returned 1 exit status
>>> make[3]: *** [alh] Error 1
>>> make[3]: Leaving directory
>>> `/users/thomas/epics/extensions/src/alh1_2_24/O.linux-x86_64'
>>> make[2]: *** [install.linux-x86_64] Error 2
>>> make[2]: Leaving directory
>>> `/users/thomas/epics/extensions/src/alh1_2_24'
>>> make[1]: *** [alh1_2_24.install] Error 2
>>> make[1]: Leaving directory `/users/thomas/epics/extensions/src'
>>> make: *** [src.install] Error 2
>>> Zhichu Chen wrote:
>>>> Then maybe your /usr/lib(64) is not included in the LIB variable. It
>>>> happened to me before, when I was compiling EDM on a 64bit ubuntu
>>>> using GCC 4.3.3, it can't find libXm, blahblah. Well, since that's not
>>>> my laptop and I'm not supposed to jeopardize the system environment, I
>>>> just make some symbolic links to /base/lib so it can move on to the
>>>> next step. I'm not sure if this message could be helpful.
>>>> On Thu, Sep 24, 2009 at 10:35 AM, Patrick Thomas
>>>> <[email protected]> wrote:
>>>>> There is a copy there as well.
>>>>> Mark Rivers wrote:
>>>>>> I think that is the 32-bit version, and you need the 64-bit version,
>>>>>> which
>>>>>> will be in usr/lib64
>>>>>> Mark
>>>>>> Sent: Wed 9/23/2009 9:02 PM
>>>>>> To: Zhichu Chen
>>>>>> I think it is installed, there is a libncurses.so.5 file in /usr/lib.
>>>>>> Zhichu Chen wrote:
>>>>>>> Install ncurses library by yourself.
>>>>>>> On Thu, Sep 24, 2009 at 9:47 AM, Patrick Thomas
>>>>>>>> Thank you, that seems to have worked. However, now it errors on
>>>>>>>> 'cannot
>>>>>>>> find
>>>>>>>> -lncurses' for g++ -o alh.
>>>>>>>> Mark Rivers wrote:
>>>>>>>>> This is a common change required in 3.14.11.
>>>>>>>>> You need to "#include menuYesNo.h" and YES needs to be changed to
>>>>>>>>> menuYesNoYES.
>>>>>>>>> Mark
>>>>>>>>> Sent: Wed 9/23/2009 8:00 PM
>>>>>>>>> To: [email protected]
>>>>>>>>> Subject: alarm handler on base 3-14-11
>>>>>>>>> Hi,
>>>>>>>>> I was wondering, I get a compile error on force.c when running
>>>>>>>>> make on
>>>>>>>>> the alarm handler with epics-3-14-11, on 64 bit linux:
>>>>>>>>> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>>>>>>>>> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
>>>>>>>>> -D_REENTRANT -O3 -Wall -m64 -g -I. -I../O.Common -I.
>>>>>>>>> -I../os/default -I.. -I../../../include/os/Linux
>>>>>>>>> -I../../../include
>>>>>>>>> -I/users/thomas/epics/base/base-3-14-11/include/os/Linux
>>>>>>>>> -I/users/thomas/epics/base/base-3-14-11/include -I../os/Linux
>>>>>>>>> -I../os/default -I/usr/include -I/usr/include/X11 ../force.c
>>>>>>>>> ../force.c: In function 'forcePVUpdateFields':
>>>>>>>>> ../force.c:1028: error: 'YES' undeclared (first use in this
>>>>>>>>> function)
>>>>>>>>> ../force.c:1028: error: (Each undeclared identifier is reported
>>>>>>>>> only
>>>>>>>>> once
>>>>>>>>> ../force.c:1028: error: for each function it appears in.)
>>>>>>>>> make[2]: *** [force.o] Error 1
>>>>>>>>> make[1]: *** [install.linux-x86_64] Error 2
>>>>>>>>> make: *** [alh1_2_24.install] Error 2
>>>>>>>>> Thank you,
>>>>>>>>> Patrick
- Re: alarm handler on base 3-14-11 Patrick Thomas
- alarm handler on base 3-14-11 Patrick Thomas
- RE: alarm handler on base 3-14-11 Mark Rivers
- Re: alarm handler on base 3-14-11 Zhichu Chen
- Re: alarm handler on base 3-14-11 Matthieu Bec
<2009>
2025
2026
<2009>
2025
2026
