just to roll it up, but it's a little bit weird Patrick's build failed
on linking, one would have expect it to happen earlier when it cannot
find the headers that are normally come in the dev packages.
Does alh actually uses curses? I remember it as an X11/Xm app.
I am thinking the real issue might be too many default options in
extensions/configure
Matthieu
On 09/24/09 02:19, Patrick Thomas wrote:
Thank you everyone!
Thomas Birke wrote:
Mark Rivers wrote:
lrwxrwxrwx 1 root root 27 Feb 20 2008 /usr/lib64/libncurses.so ->
../../lib64/libncurses.so.5
And that's the one, the linker needs to find during linking.
On a Debian system, for every library like ncurses5, there's also a
"dev" package that you have to install if you want to use the library
for development purpose.
This "dev" package (libncurses5-dev) is the one, that draws the
necessary sym-links needed to link own programs to the
libncurses-library.
Maybe it's something like this, that's causing the problem...
Thomas
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- alarm handler on base 3-14-11 Patrick Thomas
- RE: alarm handler on base 3-14-11 Mark Rivers
- Re: alarm handler on base 3-14-11 Patrick Thomas
- Re: alarm handler on base 3-14-11 Zhichu Chen
- Re: alarm handler on base 3-14-11 Matthieu Bec
Re: gnumake <arch> does not filter out unwished targets on R3.14.11 Andrew Johnson
Re: db folder Patrick Thomas
<2009>
2025
2026
Re: alarm handler on base 3-14-11 Thomas Birke
<2009>
2025
2026
