1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: db folder
To: Jason Tiller <[email protected]>
Cc: [email protected]
Date: Sat, 26 Sep 2009 09:42:00 -0700
If the IOCs are basically running the same executable, the under <app>/ iocBoot create multiple boot directories; each st.cmd 'customizes' the IOC but all references to common .db, .dbd, etc are identical.
On 25 Sep 2009, at 7:27 PM, Jason Tiller wrote:
Hi, Patrick, :)
On Fri, 25 Sep 2009, Patrick Thomas wrote:
What should I do if I have multiple iocs under the same top
directory, and they all use a common .db file? Is there a similar Db
directory to put them in that is not specific to one application?
I, too, am a very new EPICSonian.  When I encountered this problem, I
learned that trying to maintain multiple copies became unwieldy very
quickly, especially with four or five controls weenies trying to use
it simultaneously.
My solution was to write a module that holds the shared DB files.
Then include your new module in all of the IOCs that need it.  If
they're just DB files (not templates), then you can place
DB_INSTALLS += $(YOUR_MODULE)/db/your_db_file.db
in your Db/Makefile.  This will copy the module's .db into your 'db'
directory.
---Jason
db folder Patrick Thomas
Re: db folder Andrew Johnson
Re: db folder Patrick Thomas
RE: db folder Mark Rivers
Re: db folder Jason Tiller
Prev: Re: db folder Tim Mooney
Next: Re: alarm handler on base 3-14-11 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: db folder Jason Tiller
Next: Re: db folder Tim Mooney
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
