1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: RE: error building mca6-11
To: <[email protected]>
Date: Thu, 26 Nov 2009 23:56:43 -0600
My understanding is that the GigE standard is not currently an API standard, just a protocol standard.  So I think my Prosilica driver will not work with other cameras, but I have not tried it.  There is a non-finalized standard that will make it possible to write a driver that should work with any camera, but last I looked it had not been released.  For Firewire, on the other hand, the DCAM standard does allow a single driver to work with any camera.
Sent: Thu 11/26/2009 9:37 PM
To: Mark Rivers
Cc: tech-talk
Subject: Re: RE: error building mca6-11
hi, Mark:
  More questions, can  the areaDector support for other camera such as DALSA's product which compliants with GIGE standard? or it only support Prosilica?
======= At 2009-11-22, 08:41:46 you wrote: =======
>I just double-checked my system and I realized actually ran into the same problem with libnet 1.1.2.1-11 a couple of years ago.  I fixed it by simply removing the "inline" keyword from that line in libnet-functions.h.
>I looked at a more recent version of libnet (1.1.4-3) and the inline keyword is not present in that version of libnet-functions.h
>Mark
>________________________________
>From: [email protected] on behalf of Bruce Hill
>Sent: Fri 11/20/2009 8:51 PM
>To: [email protected]
>Cc: tech-talk
>Subject: Re: error building mca6-11
>I had a similar problem where I needed to compile some code
>I was sharing with a non-epics app and I needed to compile it
>without -ansi.
>Turning it off in epics base config files is asking for trouble as it
>will affect all compiles of base, modules, IOC's, etc.
>Since -ansi is selecting the language standard, you can't just turn it off
>with a compile flag.   Instead, you have to select a different language
>standard.    The default gnu std for c files is gnu89, but others are
>available as well, such as c89, c99, gnu99, etc.    See the gcc man page
>for details.
>For my directory that had this problem, I added the following line in that
>directory's Makefile after including $(TOP)/configure/CONFIG.
>   USR_CFLAGS      +=  -std=gnu99
>- Bruce Hill
>Silver wrote:
>       hi,  Michael:
>           so how to solve it? close the ansi switch in epics base's configure files? will it influence the base?
>       ======= At 2009-11-20, 22:41:31 you wrote: =======
>               This is an '-ansi' problem.
>               On my Debian system (libnet 1.1.2.1-2) line 1432 of libnet-functions.h
>               looks like
>                       inline u_int32_t
>               The 'inline' keyword isn't part of ANSI C89 and can't be used when
>               compiling with '-ansi', which EPICS Base does by default.
>               Michael Davidsaver
>               NSLSII Controls Group
>               Brookhaven National Lab
>                       -----Original Message-----
>                       From: [email protected] [mailto:tech-talk-
>                       [email protected]] On Behalf Of Silver
>                       Sent: Friday, November 20, 2009 12:28 AM
>                       To: tech-talk
>                       Subject: error building mca6-11
>                       hi,
>                       when I tried to compile the mcaR6-11/10, I met following errors:
>                       /usr/bin/gcc-4.2 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -
>                       D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -
>                       D_REENTRANT -ansi   -O3   -Wall     -g `libnet-config --defines`
>               -m32
>                       -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -
>                       I../../../include  -I/usr/local/epics/r3.14.10/modules/soft/seq/2-0-
>                       12/include
>               -I/usr/local/epics/r3.14.10/modules/soft/calc/2-6-7/include
>                       -I/usr/local/epics/r3.14.10/modules/soft/sscan/2-6-5/include  -
>                       I/usr/local/epics/r3.14.10/modules/soft/busy/1-1/include  -
>                       I/usr/local/epics/r3.14.10/modules/soft/std/2-6/include    -
>                       I/usr/local/epics/r3.14.10/modules/soft/asyn/4-12/include -
>                       I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include/os/Linux -
>                       I/usr/local/epics/r3.14.10/modules/soft/mca/6-11/include -
>                       I/usr/local/epics/r3.14.10/base/include/os/Linux -
>                       I/usr/local/epics/r3.14.10/base/include        ../nmc_comm_subs_1.c
>                       In file included from /usr/include/libnet.h:124,
>                                        from ../nmc_sys_defs.h:56,
>                                        from ../nmc_comm_subs_1.c:69:
>                       /usr/include/./libnet/libnet-functions.h:1432: error: expected '=',
>                       ',', ';', 'asm' or '__attribute__' before 'u_int32_t'
>                       make[3]: *** [nmc_comm_subs_1.o] Error 1
>                       make[3]: Leaving directory
>                       `/usr/local/epics/r3.14.10/modules/soft/mca/6-
>                       11/mcaApp/CanberraSrc/O.linux-x86'
>                       make[2]: *** [install.linux-x86] Error 2
>                       make[2]: Leaving directory
>                       `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp/CanberraSrc'
>                       make[1]: *** [CanberraSrc.install] Error 2
>                       make[1]: Leaving directory
>                       `/usr/local/epics/r3.14.10/modules/soft/mca/6-11/mcaApp'
>                       make: *** [mcaApp.install] Error 2
>                       root@cow1:/usr/local/epics/r3.14.10/modules/soft/mca/6-11#
>                       Any suggestion?  thanks a lot.
>                       ps, I use ubuntu, libnet1 with apt-get install ,not from source
>                       compilation.
>                       Best regards
>                       Geyang  2009-11-20
>       Best regards
>       Geyang 2009-11-21
>Bruce Hill
>Member Technical Staff
>SLAC National Accelerator Lab
>2575 Sand Hill Road M/S 94
>Menlo Park, CA  94025
Best regards
Geyang 2009-11-27
error building mca6-11 Silver
RE: error building mca6-11 Davidsaver, Michael
Re: RE: error building mca6-11 Silver
Re: error building mca6-11 Bruce Hill
RE: error building mca6-11 Mark Rivers
Prev: Re: RE: error building mca6-11 Silver
Next: CA problem w EPICS 3.14.11 & VxWorks 6.7 GOURNAY Jean-Francois
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: RE: RE: error building mca6-11 Silver
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
