Paul Hamadyk wrote:
On Thu, 2009-12-17 at 09:07 -0500, Wesley Moore wrote:
I'm using the CJ1's as well paired with the ETN21 Ethernet module. I
believe one I'm using has the built in Ethernet but it's basically the
same. The Ethernet driver uses the FINS protocol. I can read/write
bits or words to the PLC. The memory areas I read/write to are DM, CIO,
WR, and HR. I've found pretty quick that reading by word and splitting
out the bits to individual bi and bo's was the way to go. Much faster
that way. I've got the driver working in EPICS 3.13 and 3.14.
Wesley
I will be making a streams protocol file for FINS/UDP, using asyn's
UDP/IP for the request and UDP/IP Server for the reply, if you're
interested? Can you think of any advantages in using your Ethernet
driver?
We tend to use Data Memory (DM) with a bit of Core IO (CIO) and
Auxiliary Registers (AR) for PLC status and error information.
Paul.
Paul,
I'd be interested in using that at a later date. The biggest part
of why I went the driver route was that I started with one from KEK.
The driver didn't work out of the box, parts of the FINS protocol were
hard coded and some data types didn't work. One thing to be mindful of
is the Gateway Counter. It's set to 2 or 7 I believe. Either way, the
EPICS side just has to match. As far as memory areas, I use the HR area
for interlocks that need to hold through a power cycle.
Wesley
begin:vcard
fn:Wesley Moore
n:Moore;Wesley
org:Thomas Jefferson National Accelerator Facility;Free Electron Laser
adr:Suite 19, MS 18;;12000 Jefferson Avenue;Newport News;VA;23606;USA
email;internet:[email protected]
title:FEL Computer Scientist
tel;work:(757) 269-6033
tel;fax:(757) 269-6384
tel;pager:(757) 584-6033
url:http://www.jlab.org/FEL/
version:2.1
end:vcard
- Remote I/O nick.rees
- Re: Remote I/O Matthias Clausen
- Re: Remote I/O Ralph Lange
- RE: Remote I/O Dalesio, Leo
- Re: Remote I/O Wesley Moore
- Re: Remote I/O Paul Hamadyk
Re: Remote I/O David Dudley
Re: mbboDirect problem Andrew Johnson
<2009>
2025
2026
<2009>
2025
2026
