1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 12 Mar 2010 10:51:21 -0500
Mark Rivers wrote:
Lewis,
EPICS is advertised to build on Windows with only "make" and "perl"
(plus a MS compiler) required.  Windows does not come with a shell that
will understand Dirk's script, right?  So what shell would you point to?
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of J. Lewis Muir Sent: Friday, March 12, 2010 9:39 AM To: EPICS Tech-Talk Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
On 3/12/10 9:34 AM, John Dobbins wrote:
J. Lewis Muir wrote:
On 3/11/10 10:55 PM, Mark Rivers wrote:
I don't think shell is important on Windows, you can build EPICS in
a
Cygwin bash shell or a Windows cmd shell without having to worry
about
it.
Hi, Mark.
Note I'm not talking about the shell from which the make command is
executed; I'm talking about the shell that make uses to execute
commands
for a given target.
Lewis
Lewis, Mark, All,
It seems to me that an easy thing would be to write a Perl script that
replicates this code (which is just generating a test file):
# create stream.dbd from all RECORDS
$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
    @for r in $(RECORDS); \
    do     echo "device($$r,INST_IO,dev$${r}Stream,\"stream\")"; \
    done > $@
    @echo "driver(stream)" >> $@
    @echo "variable(streamDebug, int)" >> $@
    @echo "registrar(streamRegistrar)" >> $@
endif
I can do that but am not sure about how to invoke the Perl script and
pass from $(RECORDS) to the Perl script.
It would be nice to not have this one part of EPICS dependent on
cygwin
when the rest it not.
Hi, John.
That would work, but I'm not convinced this one part is dependent on
Cygwin.  I still think the problem is just that the target commands are
getting passed to either the wrong shell or a broken shell.
Lewis
This is true, so far I have only installed Make from GnuWin23 and Perl. I can look at adding a bash shell but I have built Base and almost all of synApps without one.
John
Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Prev: RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
Next: Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
