1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 12 Mar 2010 09:58:56 -0600
On 3/12/10 9:47 AM, Mark Rivers wrote:
> Lewis,
> EPICS is advertised to build on Windows with only "make" and "perl"
> (plus a MS compiler) required.  Windows does not come with a shell that
> will understand Dirk's script, right?  So what shell would you point to?
Hi, Mark.
OK, I see.  I didn't know that EPICS was supposed to build w/ only
"make" and "perl".  In that case, the for loop command for the target to
build stream.dbd is clearly intended to be run by a Bourne shell and
thus will not work if that shell is not present.  So the make target is
broken.  It needs to be changed to use perl to do the for loop (or maybe
there's some way to do it w/ GNU make built-in commands).
Lewis
Re: Building StreamDevice 2-4 / SynApps / Win32 Andrew Johnson
Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Prev: Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Next: Re: Building StreamDevice 2-4 / SynApps / Win32 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
