After. Someone in our group ran into this problem last fall with a
device support to bridge to snmp, which apparently has really long
names.
Michael
> -----Original Message-----
> From: Steve Kinder [mailto:[email protected]]
> Sent: Monday, March 15, 2010 1:09 PM
> To: Davidsaver, Michael; Andrew Johnson
> Cc: [email protected]
> Subject: Re: INP field length
> Hi David
> No I don't actually see an error at the moment and things work. I
> really
> wanted to make sure I understood any limitations of this sort that
> exist and
> would limit the combined length of the DEVICE and port strings in my
> case.
> You seem to be saying that the INP string needs to be less than 80
> characters. Would that be before or after macro expansion? For now I
> don't
> think either cause me a problem with a limit of 80.
> Regards
> Steve
> From: "Davidsaver, Michael" <[email protected]>
> To: "Andrew Johnson" <[email protected]>; "Steve Kinder"
> <[email protected]>
> Cc: <[email protected]>
> Sent: Monday, March 15, 2010 4:29 PM
> Subject: RE: INP field length
> Steve,
> One of the limitations on the length of INP or OUT is dbPutString in
> dbStaticLib.c (search for 'string[80]'). When you reach this limit
you
> will see the message "dbPutString received a string that is too long".
> Do you see this?
> Michael
> > From: [email protected] [mailto:tech-talk-
> > [email protected]] On Behalf Of Andrew Johnson
> > Sent: Monday, March 15, 2010 12:12 PM
> > To: Steve Kinder
> > Hi Steve,
> > On Monday 15 March 2010 10:46:42 Steve Kinder wrote:
> > > Thanks for the reply, that was what I thought. But just to clarify
> my
> > > specific case. I'm using StreamDevice2 and have a INP field as
> > follows with
> > > template/substitution.
> > > field(INP, "@TEST.protocol getCs($(DEVICE),C2,C3,C4) $(port) 0")
> > > If I understand things correctly, whatever the length of DEVICE
and
> > port I
> > > shouldn't encounter problems. Well due to the length of the field
> at
> > least.
> > I just checked something else and found a 1023 character length
limit
> > to each
> > input line before and after macro expansion in the parser, although
I
> > don't
> > think that will affect you.
> > - Andrew
> > The best FOSS code is written to be read by other humans -- Harald
> > Welte
- INP field length Steve Kinder
- Re: INP field length Andrew Johnson
- Re: INP field length Steve Kinder
- RE: INP field length Davidsaver, Michael
Re: ChannelArchiver on Solaris? Matthias Clausen
<2010>
2025
2026
Re: INP field length Dirk Zimoch
<2010>
2025
2026
