1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn and I/O intr scanning
To: "Hinko Kocevar" <[email protected]>, "Eric Norum" <[email protected]>
Cc: [email protected]
Date: Mon, 23 Aug 2010 08:21:59 -0500
It is still possible to make the EPICS records be I/O Intr scanned, i.e. processed only when there is new information from the device, even though the device does not send "unsolicited messages" when that happens.
If you write an asyn port driver that polls the device rapidly, it can parse the replies and do interrupt callbacks to device support when the values have changed.  This can be particularly efficient if your device sends multiple values in one response.  If you make your driver inherit from the asynPortDriver C++ class then most of the details of how to accomplish this are taken care of for you.
Here is an (incomplete and untested) code snippet:
void myPortDriver::pollThread()
    while(1) {
          status = pasynOctetSyncIO->writeRead(pasynUserHMS, sendMessage, numSend,
                                         receiveMessage, sizeof(receiveMessage),
                                         WRITE_READ_TIMEOUT, &numSent, responseLen, &eomReason);
          sscanf(receiveMessage, "TEMP=%f,CURRENT=%f", &temperature, &current);
          setDoubleParam(temperatureParam, temperature);
          setDoubleParam(currentParam, current);
          callParamCallbacks();
          epicsThreadSleep(POLL_DELAY);
This sets the values in a "parameter library" and then does callbacks to device support if the values have changed.  The records can then be I/O Intr scanned, and will then only process when the values have changed.  The records can also be periodically scanned, and will then just get the latest values from the parameter library, i.e. without actually doing I/O to the device.
Sent: Mon 8/23/2010 5:19 AM
To: Eric Norum
Subject: Re: Asyn and I/O intr scanning
On 08/20/10 17:41, Eric Norum wrote:
> On Aug 19, 2010, at 11:37 PM, Hinko Kocevar wrote:
>> Hi,
>> On 08/19/10 21:35, Eric Norum wrote:
>>> What low-level driver are you using?  i.e. what drvAsyn.......Configure command are you using to create the port in question?
>> I'm using drvAsynIPPortConfigure() to configure access to my network
>> device that implements SCPI interface. This is not a hardware GPIB device.
> The devGpib device support above an ASYN IP Port driver does not handle SRQ processing nor unsolicited input of any kind.
OK then. I think this is my problem, since my device is accessible only
by 'telnet like' protocol, no other interface is possible. I'm not sure
if any SRQs are sent out at all by the device..
> The devGpib device support above the VXI-11 driver driver does handle SRQs.  Does your device provide a VXI-11 interface?
> An alternative solution might be to switch to streamDevice device support which does provide support for I/O Intr operations.
> Can you provide some more details of the communication protocol that you're using?   How does the device send SRQs?  What I/O Intr operations do you want to implement?
The device has a simple network access (via e.g. telnet) that allows for
sending and receiving the SCPI messages.
Now that you explained a bit what is needed to make I/O Intr work, I
don't think it is possible to get the I/O Intr SRQ.
I basically want to monitor a set of values via EPICS monitor mechanism,
so my initial goal was make them refresh on timely basis.
Thanks for the help!
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si <http://www.i-tech.si/>  - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: Asyn and I/O intr scanning Hinko Kocevar
Re: Asyn and I/O intr scanning Eric Norum
Prev: Re: msi again Benjamin Franksen
Next: Re: msi again Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn and I/O intr scanning Hinko Kocevar
Next: Re: Asyn and I/O intr scanning Hinko Kocevar
