1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_create_channel memory management
To: "Andrew Johnson" <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 28 Jan 2011 10:47:00 -0800 (PST)
Do you mean to make certain that anything I set puser to is a valid
argument to free? And that it will be ok to set puser to 0, since free(0)
is a valid call?
> On Friday 28 January 2011 12:20:26 [email protected] wrote:
>> I'm not sure what you mean by "never set puser to anything else other
>> than
>> zero."?
> Sorry, that was badly worded.  I just meant to say that you should only
> call
> your cleanup() routine for channels that have puser set to a value that is
> to
> be passed to free(), and that it is legal to call free(0).
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
ca_create_channel memory management pthomas
Re: ca_create_channel memory management Andrew Johnson
Re: ca_create_channel memory management pthomas
Prev: Re: ca_create_channel memory management Andrew Johnson
Next: Setting BPTR Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ca_create_channel memory management Tim Mooney
