> You can add the following line in your startup script
> bspExtVerbosity=0
I like to reset bspExtVerbosity=1 after iocInit since at that point, I want to know if there's something that "kills real-time performance".
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Kate Feng
> Sent: Tuesday, March 01, 2011 9:29 AM
> To: Jim Eastman
> Cc: EPICS Tech Talk
> Subject: Re: Problem with Motor Record on RTEMS on MVME5500
> Jim Eastman wrote:
> > Hi Kate,
> > Thank you very much for that! That did the trick.
> bspExtVerbosity=0
> For example, before the line of
> dbLoadDatabase("/epics/mvme5500/dbd/motorRecord.dbd")
> This will take out all of the warning lines
> > libbspExt - Warning: it seems that MCP support is not available on
> > your CPU
> > or not implemented by your board. Address probing
> > must
> > be performed in polling mode with interrupts
> > disabled
> Regards,
> Kate
> > Regards,
> > Jim Eastman
> > From: Kate Feng [mailto:[email protected]]
> > Sent: Tue 01-Mar-11 08:54
> > To: Jim Eastman
> > Cc: EPICS Tech Talk
> > Jim Eastman wrote:
> > > Hi all,
> > > So continuing to learn my way through all of this, I'm encountering a
> > > problem with using the motor record to control a MAXv. The basic
> > > setup: an MVME5500 running RTEMS 4.10 (with the bspExt code for the
> > > mvme5500), and I've tried both 3.14.11 and 3.14.12 versions of EPICS
> > > using version 6-5-2 of the motor record. Building and deploying the
> > > NoAsyn example app.
> > > Here is my startup output:
> > > Welcome to rtems-4.10.0(PowerPC/Generic (classic FPU)/mvme5500) on
> > > MVME5500-0163
> > > Now BSP_mem_size = 0x1FE00000
> > > Marvell GT64260B (Discovery I) hostbridge detected at bus0 slot0
> > > BSP unlisted vendor, Bus0 Slot10 DeviceID 0x263388
> > > TUNDRA PCI-VME bridge detected at bus1 slot0
> > > Marvell GT64260B (Discovery I) hostbridge detected at bus8 slot0
> > > BSP unlisted vendor, Bus8 Slot10 DeviceID 0x10088086
> > > Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
> > > Universe Master Ports:
> > > Port VME-Addr Size PCI-Adrs Mode:
> > > 0: 0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
> > > 1: 0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
> > > 2: 0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
> > > Universe Slave Ports:
> > > 0: 0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN,
> > > PREN
> > > Overriding main IRQ line PCI info with 76
> > > Registering /dev/console as minor 0 (==/dev/ttyS0)
> > > ***** Initializing network *****
> > > Startup.
> > > Attaching MVME5500 1GHz NIC1
> > > RTEMS-mvme5500 BSP Copyright (c) 2004,2005,2008, Brookhaven National
> > > Lab., Shuchen Kate Feng
> > > ***** Initializing NFS *****
> > > Mount 10.40.30.108:/tftpboot/epics on /epics
> > > RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> > > LICENSE file for licensing info.
> > > RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
> > > ***** Starting EPICS application *****
> > > #Startup script for loading and configuring an OMS MAXv controller.
> > > < /epics/mvme5500/envPaths
> > > epicsEnvSet("ARCH","RTEMS-mvme5500")
> > > epicsEnvSet("IOC","iocNoAsyn")
> > > dbLoadDatabase("/epics/mvme5500/dbd/devOms.dbd")
> > > dbLoadDatabase("/epics/mvme5500/dbd/NoAsyn.dbd")
> > > NoAsyn_registerRecordDeviceDriver(pdbbase)
> > > dbLoadTemplate("/epics/mvme5500/motor.substitutions")
> > > MAXvSetup(1, 16, 0xF000, 190, 5, 10)
> > > MAXvConfig(0, "AX LL PSO; AY LL PSO; AZ LL PSO; AT LL PSO; AU LH PSO;
> > > AV LH PSO; AR LH PSO; AS LH PSO;")
> > > iocInit
> > > Starting iocInit
> > > ## EPICS R3.14.12 $Date: Wed 2010-11-24 14:50:38 -0600$
> > > ## EPICS Base built Feb 25 2011
> > > your CPU
> > > must
> > > disabled
> > > Warning: bspExtMemProbe kills real-time performance.
> > > Your BSP does or can not use MCP exceptions - we
> > > must probe with INTERRUPTS DISABLED !!!
> > > use only during driver initialization
> > > clear the 'bspExtVerbosity' variable to silence this warning
> > > Illegal field value PV: IOC:m1 motor_init_record_com(): card does not
> > > exist!
> > The jumper on the board is manufactured set to be "user mode". One
> > needs to set it
> > to a "Supervisory mode" to get it working. Hope this helps. I would
> > have to find the
> > user's manual to find out which jumper it is.
> > Cheers,
> > Kate
> > > Illegal field value PV: IOC:m2 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m3 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m4 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m5 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m6 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m7 motor_init_record_com(): card does not
> > > exist!
> > > Illegal field value PV: IOC:m8 motor_init_record_com(): card does not
> > > exist!
> > > iocRun: All initialization complete
> > > Here's what my motor.substitutions file looks like:
> > > file "/epics/mvme5500/db/basic_motor.db"
> > > pattern
> > > {P, N, M, DTYP, C, S, DESC,
> > > EGU, DIR, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES,
> > > PREC, DHLM, DLLM, INIT, PREM, POST}
> > > {IOC:, 1, "m$(N)", "OMS MAXv", 0, 0, "motor axis $(N)",
> > > degrees, Pos, 1, .1, .2, 0, 1, .2, 0.01,
> > > 5, 100, -100, "AN LL", "AF", "AN"}
> > > {IOC:, 2, "m$(N)", "OMS MAXv", 0, 1, "motor axis $(N)",
> > > {IOC:, 3, "m$(N)", "OMS MAXv", 0, 2, "motor axis $(N)",
> > > {IOC:, 4, "m$(N)", "OMS MAXv", 0, 3, "motor axis $(N)",
> > > {IOC:, 5, "m$(N)", "OMS MAXv", 0, 4, "motor axis $(N)",
> > > {IOC:, 6, "m$(N)", "OMS MAXv", 0, 5, "motor axis $(N)",
> > > {IOC:, 7, "m$(N)", "OMS MAXv", 0, 6, "motor axis $(N)",
> > > {IOC:, 8, "m$(N)", "OMS MAXv", 0, 7, "motor axis $(N)",
> > > I'm not sure why I'm not able to communicate with the MAXv controller
> > > ( maybe it has something to do with the bspExt warnings? ). I hope
> > > that covers the relevant details. Any help or advice would be greatly
> > > appreciated. Thanks!
> > > Regards,
> > > Jim Eastman
> > > This e-mail and any attachment(s) are from Pro-Dex, Inc. and may
> > > contain information that is confidential or privileged. If you are not
> > > the intended recipient, do not read, copy or distribute the e-mail or
> > > any attachments. Instead, please notify the sender at the phone number
> > > indicated above and delete the e-mail and any attachments. Thank you.
- Problem with Motor Record on RTEMS on MVME5500 Jim Eastman
- Re: Problem with Motor Record on RTEMS on MVME5500 Kate Feng
- RE: Problem with Motor Record on RTEMS on MVME5500 Jim Eastman
RE: edl2boy? Chen, Xihui
How to know if a PV is on a Soft IOC or not ? haquin
<2011>
2025
2026
<2011>
2025
2026
