1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to use asyn with linux-GPIB
To: Rod Nussbaumer <[email protected]>
Cc: [email protected]
Date: Wed, 16 Mar 2011 10:01:38 +0800
Hi Nussbaumer
Actually, I do plant to use StreamDevice in this case, and I'm already
using it to control devices via RS232. But when I try to setup the
GPIB port which can be later refer by StreamDevice, I got the errors
mentioned above.
Can you offer me some details on the use of StreamDevice with GPIB
port? Is there any options or command I missed besides
"GpibBoardDriverConfig"?
On Wed, Mar 16, 2011 at 12:15 AM, Rod Nussbaumer <[email protected]> wrote:
> Laurence:
> I find it much more convenient to use streamDevice in conjunction with asyn
> for communicating with GPIB devices. Linux-gpib with asyn and streamDevice
> is the standard model used at TRIUMF for all GPIB communications in EPICS.
> Like any communications channel used by asyn, the startup script must
> configure the port driver. In your case it would be the GPIB driver. The
> details for setup of the linux-GPIB port driver are outlined in
> 'documentation/asynDriver.html#PortDrivers'
> included in the asyn package.
> Rod Nussbaumer
> ISAC Controls, TRIUMF
> Vancouver, Canada
> Feng Laurence wrote:
>> Hi everyone~
>> I'm trying to connect a scope via linux-GPIB. The driver had been
>> setup and read/write to the scope was successfully tested with
>> "ibtest"
>> But when typing in iocsh the command
>> GpibBoardDriverConfig("L2",1,0,3,0)
>> I got the error:
>> 2011/03/14 21:48:44.176 L2 addr -1 : EDVR 0: OS error.
>> libgpib: invalid descriptor
>> ........ alot of repeat lines.......
>> Looks like the GPIB device address was not set correctly. However, I
>> can find no hints in the asyn document for the problem. Is there
>> anything I missed here?
>> Laurence Feng
>> Superconducting Radio Frequency Group
>> State Key Laboratory of Nuclear Physics and Technology
>> Peking University, 302 Chengfu Road
>> Beijing 100871 China
Laurence Feng
Autosave config file Abadie Lana
How to use asyn with linux-GPIB Feng Laurence
Re: How to use asyn with linux-GPIB Rod Nussbaumer
Prev: Re: class library header file naming and install conventions Bruce Hill
Next: Autosave config file Abadie Lana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to use asyn with linux-GPIB Eric Norum
