1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Autosave config file
Date: Wed, 16 Mar 2011 12:20:25 +0100
Hi all
I would like to know if somebody can help me with autosave utility.
I have a few questions:
1. in the xxxsaveRestore.cmd
There is the function save_restoreSet_status_prefix : what is the use of this function since we specify the value of the prefix when calling dbLoadRecords and assigning the proper value to the macro
I tried to out two different values as shown below. The only differences between the two is when I start the ioc, it complains that it could not read status value:
epics> save_restore: Can't connect to all status PV(s)
save_restore: Can't connect to status PV(s) for list 'plc-sample.sav'
### save_restore setup
# status-PV prefix
save_restoreSet_status_prefix("blabla:")
# Use status-PV
save_restoreSet_UseStatusPVs(1)
# Debug-output level
save_restoreSet_Debug(0)
# Ok to save/restore save sets with missing values (no CA connection to PV)?
save_restoreSet_IncompleteSetsOk(1)
# Save dated backup files?
save_restoreSet_DatedBackupFiles(1)
# Number of sequenced backup files to write
save_restoreSet_NumSeqFiles(3)
# Time interval between sequenced backups
save_restoreSet_SeqPeriodInSeconds(300)
# specify where save files should be
set_savefile_path("$(EPICS_AUTOSAVE_VAR)")
# specify what save files should be restored.  Note these files must be
# in the directory specified in set_savefile_path(), or, if that function
# has not been called, from the directory current when iocInit is invoked
# Save files associated with the request files 'auto-output.req' and
# 'auto-input.req'.  These files are the standard way to use autosave
set_pass1_restoreFile("plc-sample.sav")
# specify directories in which to to search for included request files
set_requestfile_path("./")
dbLoadRecords("$(EPICS_MODULES)/autosave/db/save_restoreStatus.db"), "P=TEST-S7-COMM:")
However the PVs related to autosave are there and autosave is working. So where i can see the impact?
2. I would like to check if i understood the policy for autosave generated files - the configuration used is the previous one
-  We have xxx.sav_<date> which says the initial values used when the ioc started :
- Then it replicates this file to a savX (circular algorithm between .sav, .sav0, sav1)
- .sav has always a backup .savB and copied to .sav sav0 or sav1 every 5mn
- we also use
create_monitor_set("plc-sample.req",30,"P=TEST-S7-COMM:") ->if a PV changes its value then it will be report on .sav or the most recent one? As i think .sav is the one used for restore
[root@current ~]# ll /var/opt/codac-2.0/autosave/ |grep plc-sample|grep 'Mar 16'
-rw-r--r-- 1 codac codac  392 Mar 16 11:58 plc-sample.sav
-rw-r--r-- 1 codac codac  392 Mar 16 11:57 plc-sample.sav0
-rw-r--r-- 1 codac codac  392 Mar 16 12:02 plc-sample.sav1
-rw-r--r-- 1 codac codac  392 Mar 16 10:53 plc-sample.sav_110316-105306
-rw-r--r-- 1 codac codac  392 Mar 16 11:02 plc-sample.sav_110316-110228
-rw-r--r-- 1 codac codac  392 Mar 16 11:57 plc-sample.sav_110316-115743
-rw-r--r-- 1 codac codac  392 Mar 16 11:52 plc-sample.sav2
-rw-r--r-- 1 codac codac  392 Mar 16 11:58 plc-sample.savB
[root@current ~]#
-rw-r--r-- 1 codac codac  371 Mar 16 12:05 plc-sample.sav
-rw-r--r-- 1 codac codac  371 Mar 16 12:12 plc-sample.sav0
-rw-r--r-- 1 codac codac  371 Mar 16 12:07 plc-sample.sav2
-rw-r--r-- 1 codac codac  371 Mar 16 12:05 plc-sample.savB
[root@current ~]#
Many thanks for your feedback and hope I'm clear
Lana
Re: Autosave config file Kasemir, Kay
Re: Autosave config file Tim Mooney
How to use asyn with linux-GPIB Feng Laurence
Re: How to use asyn with linux-GPIB Rod Nussbaumer
Re: How to use asyn with linux-GPIB Feng Laurence
Prev: Re: How to use asyn with linux-GPIB Feng Laurence
Next: Re: Autosave config file Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
