Dear Sir, I am seeking help for execution of CMLOG server and utilities. I am able to successfully compile CMLOG v2.1 utility on linux 64 bit ( on RHEL 5.5 ) plateform with kernal 2.6.x. I am facing problem to connect the client daemon to server. Client Deamon finds the server but gives error in connection to it. Am i making some configuration mistake.
I am seeking help from EPICS experts . I would also appriciate links to other useful documentation. I am currently using document supplied with the distribution. Best Regards,
Ritesh Sugandhi CMLOG Server Output $ ./cmlogServer ../../cmlog.config Wed May 4 18:23:55 2011: cmlogServer UDP port: 8900
Wed May 4 18:23:55 2011: Maximum client connections: 64 Wed May 4 18:23:55 2011: Maximum broswer connections: 16 Wed May 4 18:23:55 2011: Default directory: /tmp Wed May 4 18:23:55 2011: Server database name: /home/sugandr/CMLOG/cmlog_%s
Wed May 4 18:23:55 2011: Server context database name: /home/sugandr/CMLOG/cmlogcxt_%s Wed May 4 18:23:55 2011: Server tag table name: /home/sugandr/CMLOG/cmlogTagTable Wed May 4 18:23:55 2011: Server database name changes every 1440 minitues
Wed May 4 18:23:55 2011: Server database page size is 4096 Wed May 4 18:23:55 2011: Current limit on number of opened files is 1024 Wed May 4 18:24:00 2011: New database Filename is /home/sugandr/CMLOG/cmlog_1304526240
Wed May 4 18:24:00 2011: New Context filename is /home/sugandr/CMLOG/cmlogcxt_1304526240 Wed May 4 18:24:00 2011: cmlog server opens udp listening port 8900 Wed May 4 18:24:00 2011: cmlog server opens client connection port 42287
Wed May 4 18:24:00 2011: cmlog server opens browser connection port 46639 Wed May 4 18:24:00 2011: cmlog server opens admin connection port 52655 Wed May 4 18:24:00 2011: Starting up cmlog server with cmlog protocol version 2.x........
Client Demon output $ CMLOG_PORT=8900 $ ./cmlogClientD -s 8900 -u 42287 cmlogClientD with cmlog protocol version 2.x Find cmlog server running at port 42287 on localhost
Cannot connect to a cmlog server Starting up cmlog client daemon.... while when I run cmadmin utility , I am able to connect to server and able to remote shutdown it. But I could not able to write to cmlog server using $cmlogMsg "hello"
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
