1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Generating loadable modules for Cexp
To: Ralph Lange <[email protected]>
Date: Wed, 04 May 2011 10:51:23 -0700
Ralph Lange wrote:
Does anyone have experiences/examples of adding support to the EPICS build system for generating Cexp [1] loadable modules (instead of binaries) for RTEMS and other target archs that can use Cexp?
We would like to add that option - preferably with an easy statement in the Makefile that creates the module in addition or instead of the completely linked binary - and would like to make new mistakes instead of the old ones....
All hints, warnings, and rule snippets welcome!
~Ralph
[1] http://www.slac.stanford.edu/~strauman/rtems/cexp/
Here's is what I did for Eric Norum's "RTEMS Spy Utility":
Works great. :)
[ernesto@lcls-dev2 rtemsUtilsSup]$ more Makefile
TOP=..
include $(TOP)/configure/CONFIG
# Build as a static library for an linking
# in with an external IOC application:
LIBRARY_IOC_RTEMS += rtemsutils
# Library Source files
rtemsutils_SRCS += spy.cpp
# Link with the asyn and base libraries
rtemsutils_LIBS += $(EPICS_BASE_IOC_LIBS)
# Install .dbd and .db files
DBD += spy.dbd
# Let's build and OBJ file for loading dynamically
PROD_IOC_RTEMS += rtemsUtilsSup
# rtemsUtilsSup.dbd will be created and installed
rtemsUtilsSup_DBD += spy.dbd
DBD += rtemsUtilsSup.dbd
# rtemsUtilsSup_registerRecordDeviceDriver.cpp derives from
# rtemsUtilsSup.dbd
rtemsUtilsSup_SRCS += rtemsUtilsSup_registerRecordDeviceDriver.cpp
# Compile in the RTEMS Spy utility based on the
# RTEMS Capture Engine
rtemsUtilsSup_SRCS += spy.cpp
# Finally link to the rtemsCom
rtemsUtilsSup_LIBS += rtemsCom
include $(TOP)/configure/RULES
Generating loadable modules for Cexp Ralph Lange
Prev: Re: Generating loadable modules for Cexp Michael Davidsaver
Next: Re: EPICS and Octave Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CMLOG Execution and configuration problem Ritesh Sugandhi
