1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Generating loadable modules for Cexp
To: Ralph Lange <[email protected]>
Date: Wed, 04 May 2011 13:36:03 -0400
Hi Ralph,
See attached. This is what is in our debian packaged version of base. It applies against 3.14.11. Just set USE_GESYS=YES in configure/CONFIG_SITE for your application.
Michael
On 5/4/2011 12:33 PM, Ralph Lange wrote:
Does anyone have experiences/examples of adding support to the EPICS build system for generating Cexp [1] loadable modules (instead of binaries) for RTEMS and other target archs that can use Cexp?
We would like to add that option - preferably with an easy statement in the Makefile that creates the module in addition or instead of the completely linked binary - and would like to make new mistakes instead of the old ones....
All hints, warnings, and rule snippets welcome!
~Ralph
[1] http://www.slac.stanford.edu/~strauman/rtems/cexp/
>From 0e95a351f6cf7f4eff46c345a40bbd693fe8ce96 Mon Sep 17 00:00:00 2001
Date: Wed, 28 Oct 2009 17:34:23 -0400
Subject: RTEMS Generic System (patch v1.6)
For PROD targets build both monolithic and modular binaries
at the same time.
The option USE_GESYS can now be set in configure/os/CONFIG_SITE.Common.RTEMS
for base, in configure/CONFIG_SITE for individual projects, or from the
command line.
Includes an explicit list of libraries which are part of generic image
 configure/RULES_BUILD                 |    7 ++++++
 configure/os/CONFIG.Common.RTEMS      |   38 +++++++++++++++++++++++++++++++++
 configure/os/CONFIG_SITE.Common.RTEMS |    6 +++++
 3 files changed, 51 insertions(+), 0 deletions(-)
diff --git a/configure/RULES_BUILD b/configure/RULES_BUILD
index a83fac3..21ed8d5 100644
--- a/configure/RULES_BUILD
+++ b/configure/RULES_BUILD
@@ -312,6 +312,13 @@ $(OBJLIB_MUNCHNAME):%.munch : %_ctdt$(OBJ) %$(OBJ)
 	@$(RM) $@
 	$(MUNCH_CMD)
+# GeSys modules for RTEMS
+$(MODNAME): \
+%$(MODEXT): %$(EXE)
+	@echo "Building module $@"
+	@$(RM) $@
+	$(DEBUGCMD) $(LINK.mod)
 runtests: $(TESTSCRIPTS_$(BUILD_CLASS))
 	-$(PERL) -MTest::Harness -e 'runtests @ARGV if @ARGV;' $^
diff --git a/configure/os/CONFIG.Common.RTEMS b/configure/os/CONFIG.Common.RTEMS
index 3934cdf..555d3fa 100644
--- a/configure/os/CONFIG.Common.RTEMS
+++ b/configure/os/CONFIG.Common.RTEMS
@@ -81,6 +81,8 @@ OPT_CXXFLAGS_YES = $(CFLAGS_OPTIMIZE_V)
 OPT_CFLAGS_NO    = $(CFLAGS_DEBUG_V)
 OPT_CXXFLAGS_NO  = $(CFLAGS_DEBUG_V)
+MODEXT=.obj
 # operating system class (include/os/<os_class>)
 OS_CLASS = RTEMS
@@ -95,6 +97,42 @@ OP_SYS_LDFLAGS += $(CPU_CFLAGS) -u Init \
                  $(PROJECT_RELEASE)/lib/no-signal.rel \
                  $(PROJECT_RELEASE)/lib/no-rtmon.rel
+MOD_SYS_LDFLAGS += $(CPU_CFLAGS) -Wl,-r -nostdlib
+# Do not link against libraries which are part of the Generic Image
+GESYS_LIBS += -lgcc
+GESYS_LIBS += -lc -lm -lrtemscpu -lrtemsbsp -lrtems++ -lbspExt
+GESYS_LIBS += -lcexp -ltecla_r -lspencer_regexp -lpmelf -lpmbfd
+GESYS_LIBS += -lnfs -ltelnetd -lrtems-gdb-stub
+# While not part of the Generic Image it provides symbols which
+# would conflict.
+GESYS_LIBS += -lrtemsCom
+# Options for building GeSys loadable objects
+MODNAME_YES = $(PRODNAME:%$(EXE)=%$(MODEXT))
+MODNAME += $(MODNAME_$(USE_GESYS))
+PRODTARGETS += $(MODNAME)
+BIN_INSTALLS += $(MODNAME)
+# changes to LDFLAGS in CONFIG_COMMON and LINK.cpp in CONFIG.Common.UnixCommon
+# should be reflected here with the following exceptions
+# replace OP_SYS_LDFLAGS with MOD_SYS_LDFLAGS
+# replace PROD_LDLIBS with MOD_LDLIBS
+# remove STATIC_LDFLAGS
+MOD_LDLIBS = $(filter-out $(GESYS_LIBS),$(PROD_LDLIBS))
+MOD_LDFLAGS = $(OPT_LDFLAGS) $(TARGET_LDFLAGS) $(USR_LDFLAGS) $(POSIX_LDFLAGS) \
+ $(ARCH_DEP_LDFLAGS) $(DEBUG_LDFLAGS) $(MOD_SYS_LDFLAGS) $($(BUILD_CLASS)_LDFLAGS)\
+ $(RUNTIME_LDFLAGS) $(CODE_LDFLAGS)
+LINK.mod = $(CCC) -o $@ $(PRODDIR_LDFLAGS) $(MOD_LDFLAGS)
+LINK.mod += $(PROD_LDFLAGS) $(PROD_LD_OBJS) $(PROD_LD_RESS) $(MOD_LDLIBS)
 # RTEMS has neither shared libraries nor dynamic loading
 STATIC_BUILD=YES
diff --git a/configure/os/CONFIG_SITE.Common.RTEMS b/configure/os/CONFIG_SITE.Common.RTEMS
index cf79e32..b643529 100644
--- a/configure/os/CONFIG_SITE.Common.RTEMS
+++ b/configure/os/CONFIG_SITE.Common.RTEMS
@@ -12,6 +12,12 @@ RTEMS_VERSION=4.9.2
 RTEMS_TOOLS=$(RTEMS_BASE)
+# Link Generic System loadable objects instead of full executable.
+# A GeSys object is similar to a shared library.  It can be (un)loaded
+# at runtime by the Generic System loader which is available as a
+# patch against RTEMS.
+USE_GESYS=NO
 # If you're using neither BOOTP/DHCP nor FLASH to pick up your IOC
 # network configuration you must uncomment and specify your Internet
1.7.2.5
Generating loadable modules for Cexp Ralph Lange
Prev: EPICS and Octave Andreas Balzer
Next: Re: Generating loadable modules for Cexp Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Generating loadable modules for Cexp Till Straumann
