1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calculation in SNL/SEQ
To: liuping <[email protected]>
Cc: [email protected]
Date: Wed, 11 May 2011 08:16:21 +0200
Hello Liuping,
The warning "implicit declaration of function XXX" means that the compiler assumes the type of the function is "int XXX(...)".
So what happens? You call the function, it returns a double but the compiler doesn't know. It assumes an int and converts it to double (the type of temp). Depending on the architecture, the misinterpretation may be an int that is the result of a bitwise mapping of either the low or the high half of the double result bits or even something completely unrelated. So the "correct" result of fabs was probably pure coincidence.
By the way, this is not only true for SNL but for all C code.
Dirk
liuping wrote:
Hello,
I need your help about the calculation in SNL/SEQ.
In my SNL/SEQ application, I need to execute the mathematical operation: fabs() and exp().
Here is the codes abstracted from the my application:
double   temp;
  double  err;
  double  r1;
  double  r2;
ss test123{
         state calctest
           when(delay(2))
                r1=1.0;
               r2=2.0;
                temp=fabs(r1-r2);
                printf("fabs:  %lf\n",temp);
                temp=exp(r1+r2);
printf("exp: %lf\n", temp);
           } state calctest
The operation result is:
fabs:  1.000000
exp:  2287528.000000
fabs:  1.000000
exp:  2287528.000000
fabs:  1.000000
exp:  2287528.000000
Obviously, the result of “fabs” is right, and the other is wrong. Then I check the output of compiler. There are two warning and no error (see the bold and incline words).
make[3]: Entering directory `/home/blctrl/watercool-Mono/motorApp/OmsSrc/O.vxWorks-ppc604_long'
converting ../sncExample.stt
/home/blctrl/seq-2.0.11/bin/linux-x86/snc ../sncExample.stt -o sncExample.c.tmp
mv sncExample.c.tmp sncExample.c
/BLC/epics/Tornado2.2/host/x86-linux/bin/ccppc -c -D_POSIX_SOURCE -DCPU=PPC604 -DvxWorks -include /BLC/epics/Tornado2.2/target/h/vxWorks.h -ansi -O3 -Wall -mcpu=604 -mstrict-align -mlongcall -fno-builtin -I. -I.. -I../../../include/os/vxWorks -I../../../include -I/home/blctrl/asyn4-8/include/os/vxWorks -I/home/blctrl/asyn4-8/include -I/home/blctrl/seq-2.0.11/include/os/vxWorks -I/home/blctrl/seq-2.0.11/include -I/BLC/epics/base/include/os/vxWorks -I/BLC/epics/base/include -I/BLC/epics/Tornado2.2/target/h sncExample.c
*/../sncExample.stt: In function `A_test123_calctest':/*
*/../sncExample.stt:38: warning: implicit declaration of function `fabs'/*
*/../sncExample.stt:40: warning: implicit declaration of function `exp/**'*
perl /BLC/epics/base/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/omsMAXv.dbd omsMAXv_registerRecordDeviceDriver > temp.cpp
mv temp.cpp omsMAXv_registerRecordDeviceDriver.cpp
Again, I tried to do such process:
1)Power off the VME rack,
2)Change the value of r1 and r2:    r1=9.0;    r2=12.0;
3)make clean
4)make
5)Power on the VME rack
Sadly I saw the result was same to last test:
fabs:  1.000000
exp:  2287528.000000
fabs:  1.000000
exp:  2287528.000000
fabs:  1.000000
exp:  2287528.000000
The result of “fabs” and “exp” are both wrong. Who can tell me the reason and how to get the right result?
Any advices are appreciated!
LIU Ping
Beamline Control Group
Shanghai Synchrotron Radiation Facility
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
Zhangheng Rd 239,Pudong Dist.,
Shanghai 201204
China
Tel:+86-21-33933237(Lab)
http://ssrf.sinap.ac.cn
Calculation in SNL/SEQ liuping
Prev: Re: Calculation in SNL/SEQ Kotturi, Dayle
Next: Re: Calculation in SNL/SEQ Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: re: Calculation in SNL/SEQ liuping
Next: Pro-Dex OMS MAXv card reading limit-switches junkes
