1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: re: Calculation in SNL/SEQ
To: "'Dirk Zimoch'" <[email protected]>, "'Kotturi, Dayle'" <[email protected]>
Cc: [email protected]
Date: Thu, 12 May 2011 15:51:49 +0800
Thank your responses!
According to your ideas, I have resolved this question.
Firstly add new line in my SNL file:
%%#include "math.h"
Secondly change the variables' definition.
  float   temp;
  double  da;
  float  r1;
  float  r2;
Also there are some changes in state set.
  ss test123{
         state calctest
           when(delay(2))
                r1=1.0;
                r2=2.0;
                temp=fabs(r1-r2);
                printf("fabs:  %f\n",temp);
                da=exp(r1+r2);
                printf("exp:  %lf\n", da);
           } state calctest
When I done these modification, and tested it. I got the right result.
: [email protected] [mailto:[email protected]] Dirk
Zimoch
: 2011.5.11. 14:31
: Kotturi, Dayle
: [email protected]
: Re: Calculation in SNL/SEQ
Kotturi, Dayle wrote:
> Having just learned about pVar pointer from my colleague Kukhee Kim, I can
also offer that,
> in addition to adding '%%#include "math.h"' and prepending lines with c
function calls with '%%',
> you may also need to help the escaped c code access the SNL variables via
the pVar pointer.
>        r1=1.0;
>         r2=2.0;
>         %%pVar->temp=fabs(pVar->r1-pVar->r2);
>         printf("fabs:  %lf\n",temp);
>         %%pVar->temp=exp(pVar->r1+pVar->r2);
>         printf("exp:  %lf\n", temp);
> Without the 'pVar->', you may see these errors:
> error: `temp' undeclared (first use in this function)
> error: `r1' undeclared (first use in this function)
> error: `r2' undeclared (first use in this function)
This depends on the +/-r flag. In reentrant mode, all "global variables"
are localized by putting them into a pVar structure.
It is more portable not to access SNL variables from within %%. If
necessary write your own wrapper function within %{...}%, call the
function *without* %% and pass all necessary SNL variables as parameters.
Dirk
> Dayle
> On May 10, 2011, at 8:26 PM, Chestnut, Ronald P. wrote:
>> Dear Liuping,
>> You have to include the math libraries, as  you would for a simple "C"
program.
>> If SNL doesn't parse the libraries correctly, escape them and their use
with %%.
>> %%include math.h
>> %%temp=fabs(r1-r2);
>> Ron
>> On May 10, 2011, at 7:35 PM, liuping wrote:
>> Hello,
>> I need your help about the calculation in SNL/SEQ.
>> In my SNL/SEQ application, I need to execute the mathematical operation:
fabs() and exp().
>> Here is the codes abstracted from the my application:
>> double   temp;
>>  double  err;
>>  double  r1;
>>  double  r2;
>>  ss test123{
>>         state calctest
>>           when(delay(2))
>>                r1=1.0;
>>               r2=2.0;
>>                temp=fabs(r1-r2);
>>                temp=exp(r1+r2);
>>           } state calctest
>> The operation result is:
>> fabs:  1.000000
>> exp:  2287528.000000
>> fabs:  1.000000
>> exp:  2287528.000000
>> fabs:  1.000000
>> exp:  2287528.000000
>> Obviously, the result of "fabs" is right, and the other is wrong. Then I
check the output of compiler. There are two warning and no error (see the
bold and incline words).
>> make[3]: Entering directory
`/home/blctrl/watercool-Mono/motorApp/OmsSrc/O.vxWorks-ppc604_long'
>> converting ../sncExample.stt
>> /home/blctrl/seq-2.0.11/bin/linux-x86/snc    ../sncExample.stt -o
sncExample.c.tmp
>> mv sncExample.c.tmp sncExample.c
>> /BLC/epics/Tornado2.2/host/x86-linux/bin/ccppc -c   -D_POSIX_SOURCE
-DCPU=PPC604  -DvxWorks -include /BLC/epics/Tornado2.2/target/h/vxWorks.h
-ansi  -O3  -Wall     -mcpu=604 -mstrict-align -mlongcall    -fno-builtin
-I. -I.. -I../../../include/os/vxWorks -I../../../include
-I/home/blctrl/asyn4-8/include/os/vxWorks -I/home/blctrl/asyn4-8/include
-I/home/blctrl/seq-2.0.11/include/os/vxWorks
-I/home/blctrl/seq-2.0.11/include -I/BLC/epics/base/include/os/vxWorks
-I/BLC/epics/base/include      -I/BLC/epics/Tornado2.2/target/h
sncExample.c
>> ../sncExample.stt: In function `A_test123_calctest':
>> ../sncExample.stt:38: warning: implicit declaration of function `fabs'
>> ../sncExample.stt:40: warning: implicit declaration of function `exp'
>> perl /BLC/epics/base/bin/linux-x86/registerRecordDeviceDriver.pl
../O.Common/omsMAXv.dbd omsMAXv_registerRecordDeviceDriver > temp.cpp
>> mv temp.cpp omsMAXv_registerRecordDeviceDriver.cpp
>> Again, I tried to do such process:
>> 1)Power off the VME rack,
>> 2)Change the value of r1 and r2:    r1=9.0;    r2=12.0;
>> 3)make clean
>> 4)make
>> 5)Power on the VME rack
>> Sadly I saw the result was same to last test:
>> fabs:  1.000000
>> exp:  2287528.000000
>> fabs:  1.000000
>> exp:  2287528.000000
>> fabs:  1.000000
>> exp:  2287528.000000
>> The result of "fabs" and "exp" are both wrong. Who can tell me the reason
and how to get the right result?
>> Any advices are appreciated!
>> LIU Ping
>> Beamline Control Group
>> Shanghai Synchrotron Radiation Facility
>> Shanghai Institute of Applied Physics
>> Chinese Academy of Sciences
>> Zhangheng Rd 239,Pudong Dist.,
>> Shanghai 201204
>> China
>> Tel:+86-21-33933237(Lab)
>> http://ssrf.sinap.ac.cn<http://ssrf.sinap.ac.cn/>
Re: Calculation in SNL/SEQ Dirk Zimoch
Prev: RE: Area Detector Mark Rivers
Next: Pro-Dex OMS MAXv card reading limit-switches junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Calculation in SNL/SEQ Dirk Zimoch
Next: Re: Calculation in SNL/SEQ Dirk Zimoch
