1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [help] EPICS build no good
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 6 Dec 2011 11:39:06 +0300
Hello,
A little misprint. We've got Tektronix TDS 3054C. Look what I've found:
http://www.aps.anl.gov/epics/modules/instrument/tds3000/R2-3/tds3000Device.html
I have no idea how to use it, though. Can you give me a hint?
On Tue, Dec 6, 2011 at 10:33 AM, Dirk Zimoch <[email protected]> wrote:
Pavel,
I don't know the TDS 5054, but most oscilloscopes come with GPIB, RS232, or VXI11 (="GPIB over TCP") network interface and are controlled with text commands. In that case the combination asynDriver/StreamDevice will do the job.
http://www.aps.anl.gov/epics/modules/soft/asyn/
http://epics.web.psi.ch/software/streamdevice/
If you are lucky, someone has already written a StreamDevice protocol file for it. But if not, it is not difficult.
Here at PSI, we also run EPICS directly on some oscilloscopes. Many oscilloscopes nowadays use Windows as the operating system and come with an API to get direct access to the oscilloscope functions. This allows to write an EPICS device driver. Running the IOC directly on the oscilloscope saves some network traffic. With an external IOC, the data is first transferred from the oscilloscope to the IOC (e.g. via VXI11) and then from the IOC to the client via Channel Access. With an IOC integrated into the oscilloscope, you only have Channel Access. But writing such a driver is somewhat sophisticated.
Dirk
Pavel Masloff wrote:
Hey Andrew!!! Hi Dirk!
It worked :))
This was my first introduction to Epics. Andrew, Dirk, guys! What would you recommend me to do next? I mean, we have a Tektronix oscilloscope at work, namely TDS 5054, I guess. And I've read there's a driver written to hook it up to EPICS. How can I do it? Perhaps, I could try your PLC driver, Dirk as the next step in mastering Epics. What do you guys think?
Paul
On Mon, Dec 5, 2011 at 9:42 PM, Andrew Johnson <[email protected] <mailto:[email protected]>> wrote:
   Hi Pavel,
   On 2011-12-05 Pavel Masloff wrote:
    > D:\>softIoc -h
    > Usage: softIoc [-D softIoc.dbd] [-h] [-S] [-a ascf]
    >         [-m macro=value,macro2=value2] [-d file.db]
    >         [-x prefix] [st.cmd]
    > Compiled-in path to softIoc.dbd is:
    >         'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
   Forget my last message, the quotes are coming from this Makefile rule:
   epicsInstallDir.h:
          $(ECHO) "FINAL_LOCATION=$(FINAL_LOCATION)"
          $(PERL) ../makeInstallDir.pl '$(FINAL_LOCATION)' > $@
   On Unix the shell strips out those single quotes, but evidently
   yours is not
   doing so (my win32-x86-mingw build does strip them, but not my win32-x86
   build).  You can add two lines to the
   base/src/softIoc/makeInstallDir.pl file
   to fix this:
   === modified file 'src/softIoc/makeInstallDir.pl'
   --- src/softIoc/makeInstallDir.pl       2010-09-27 22:42:42 +0000
   +++ src/softIoc/makeInstallDir.pl       2011-12-05 18:33:24 +0000
   @@ -14,6 +14,8 @@
    my $path = shift;
    $path =~ s/\\/\\\\/gx;
   +$path =~ s/^'//x;
   +$path =~ s/'$//x;
    print "/* THIS IS A GENERATED FILE. DO NOT EDIT! */\n",
         "\n",
   I will add this change to the 3.14.12.2 release of Base.
   HTH,
   - Andrew
   Optimization is the process of taking something that works and
   replacing it with something that almost works, but costs less.
   -- Roger Needham
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
[help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Andrew Johnson
Re: [help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Dirk Zimoch
Prev: Re: [help] EPICS build no good Dirk Zimoch
Next: Re: synApps 5.6 release Fabian S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Tektronix 3000/5000 oscilloscopes Eric Norum
