Subject: Re: iocshCmd, redirection, and function pointers
To: "Kim, Kukhee" <[email protected]>, EPICS Techtalk <[email protected]>
Date: Tue, 01 May 2012 17:43:24 -0700
Hi everyone,
Looks like I have a work-around for what was happening under RTEMS while using iocshCmd:
Thanks to Till:  )
# This one does not work: as reported by Stephanie Allison in this tech-talk thread
#iocshCmd("dbior > /data/iocInfo/IOC.dbior")
# However, this one does work under RTEMS. Thanks to Till:
Cexp@ioc-b34-ev02> > "/data/iocInfo/IOC.dbior" : dbior()
Cheers,
Ernest
On 03/14/2012 05:14 PM, Kim, Kukhee wrote:
Hi Eric;
The epicsStdioRedirect.h itself already includes the epicsStdio.h file.
Probably, we should merge those two files to one file.
Thank you.
Best regards,
Kukhee
Kukhee Kim
SLAC National Accelerator Laboratory
2575 Sand Hill Rd, MS 64
Menlo Park, CA 94025
Email: [email protected]
Phone: (650)926-4912
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Eric Norum
Sent: Wednesday, March 14, 2012 8:39 AM
To: EPICS Tech Talk
On Mar 14, 2012, at 3:12 AM, Dirk Zimoch wrote:
Eric Norum wrote:
For I/O redirection to work a source file must include epicsStdioRedirect.h.
This sucks.
Perhaps, but it does work across all supported platforms.
It this is the case, I would say that there is something wrong with the EPICS redirection. Code should not need to know about its "environment". This contradicts any good programming practice.
When this was originally implemented we felt it should be optional.  Perhaps now after 10 years in the field we should just add
#include<epicsStdioRedirect.h>
in epicsStdio.h.
iocshCmd, redirection, and function pointers Allison, Stephanie
Re: iocshCmd, redirection, and function pointers Eric Norum
Re: iocshCmd, redirection, and function pointers Dirk Zimoch
RE: iocshCmd, redirection, and function pointers Kim, Kukhee
Prev: Re: iocshCmd, redirection, and function pointers Ernest L. Williams Jr.
Next: RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
Next: Re: iocshCmd, redirection, and function pointers Andrew Johnson
