On May 4, 2012, at 6:11 PM, Pavel Masloff wrote:
> Thanks Mark,
> When I save the waveforms manually on the CF card each csv file is precisely 73,5 Kb.
That's because it's storing the values as ASCII numbers.
The waveform data transfer can take place in raw binary format using one byte per point per trace as Mark pointed out.
So transferring all 2500 points from all four traces would still be only 10,000 bytes.
Eric Norum
[email protected]
- Re: [Scopes] BMP image record?? Pavel Masloff
- [Scopes] BMP image record?? Pavel Masloff
- Re: [Scopes] BMP image record?? Dirk Zimoch
- RE: [Scopes] BMP image record?? Mark Rivers
- Re: [Scopes] BMP image record?? Rod Nussbaumer
<2012>
2025
2026
<2012>
2025
2026
