Subject: Re: [Scopes] BMP image record??
To: Eric Norum <[email protected]>
Date: Sat, 5 May 2012 05:20:14 +0400
Excellent!!!
On Sat, May 5, 2012 at 5:18 AM, Eric Norum <[email protected]> wrote:
On May 4, 2012, at 6:11 PM, Pavel Masloff wrote:
> Thanks Mark,
> When I save the waveforms manually on the CF card each csv file is precisely 73,5 Kb.
That's because it's storing the values as ASCII numbers.
The waveform data transfer can take place in raw binary format using one byte per point per trace as Mark pointed out.
So transferring all 2500 points from all four traces would still be only 10,000 bytes.
Eric Norum
[email protected]
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
[Scopes] BMP image record?? Pavel Masloff
Re: [Scopes] BMP image record?? Dirk Zimoch
Re: [Scopes] BMP image record?? Pavel Masloff
RE: [Scopes] BMP image record?? Mark Rivers
Re: [Scopes] BMP image record?? Rod Nussbaumer
Re: [Scopes] BMP image record?? Eric Norum
Prev: Re: [Scopes] BMP image record?? Eric Norum
Next: Control Engineer Job in SESAME ibrahim.saleh
Next: [ASYN] connect/disconnect Pavel Masloff
