Subject: Re: aiRecord conversion
To: Ralph Lange <[email protected]>
Date: Tue, 28 Aug 2012 11:11:46 -0300
Hi Ralph,
Thanks for your advice! I'm still learning EPICS, so I'm using those A/D's just for experimenting. When it comes to the real deal, I'll keep in mind what you said.
Best regards,
Bruno Seiva Martins
On Tue, Aug 28, 2012 at 11:05 AM, Ralph Lange <[email protected]> wrote:
On Tue Aug 28 2012 15:28:34 GMT+0200 (CEST), Bruno Seiva Martins <[email protected]> wrote:
Rectifying:
   epicsFloat64 div;
   pao->eguf = 10.0;
   pao->egul = (type == LCN12BMP || type == LCN16BMP) ? 0.0 : -10.0;
   div = (type == LCN12BMP || type == LCN12BBP) ? 4095.0 : 65535.0;
   pao->hopr = pao->eguf;
   pao->lopr = pao->egul;
   pao->eslo = ((pao->eguf) - (pao->egul)) / div;
Bruno Seiva Martins
Another comment:
The linear conversion mechanism is intended to convert the digitized value into the final engineering units.
You might want to use your A/D converter for signals that correspond to positions [mm], pressures [mbar], or temperatures [C].
In those cases, the database designer will set EGU, EGUL and EGUF to e.g. "mm", -5 and 25, meaning that -10V are equivalent to -5mm, and +10V are equivalent to +25mm. To limit the range that is shown in the GUI, the designer might also want to set e.g. LOPR to -2 and HOPR to +2, so that graphs and meters show the "interesting" range, -2mm to +2mm.
To have this work correctly, setting EGUF, EGUL, HOPR and LOPR in your device support may actually not be a good idea.
Normally, I would just set ESLO and EOFF.
Cheers,
~Ralph
Re: aiRecord conversion Dirk Zimoch
aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Ralph Lange
Prev: Re: aiRecord conversion Nicholas P. DiMonte
Next: Re: aiRecord conversion Eric Norum
Prev: Re: aiRecord conversion Ralph Lange
Next: Re: aiRecord conversion Dirk Zimoch
