On the Newport XPS we switch UEIP back and forth, depending on whether we want the RBV field to hold the theoretical position or encoder position. Sometimes one does not want to see the encoder jitter, sometimes one does. This can be changed at run-time with medm, etc.
From: [email protected] [[email protected]] on behalf of J. Lewis Muir [[email protected]]
Sent: Wednesday, September 26, 2012 9:25 AM
To: [email protected]
Cc: [email protected]
Subject: Re: Motor record -- URIP with soft limits
On 9/26/12 5:21 AM, [email protected] wrote:
> Hi,
> The pmacAsynMotor driver doesn't know about the motor record UEIP or URIP fields, as these are just internal to the motor record. But the driver does set the 'encoder present' bit in the MSTA field, allowing the use of UEIP to switch between REP and RMP for the position readback.
Hi, Matt.
Thanks for the info. I guess that means my motor records that
use the pmacAsynMotor driver are configured incorrectly for what
I want (i.e. having the RBV field reflect the position reported
by the encoder). :-( I'll try changing them to have UEIP set to
Yes.
Thanks!
Lewis
- RE: Motor record -- URIP with soft limits matthew.pearson
- Motor record -- URIP with soft limits Fong, Nia W.
- Re: Motor record -- URIP with soft limits J. Lewis Muir
- Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
<2012>
2025
2026
<2012>
2025
2026
