One caveat.. Make sure the ERES field is set correctly before switching UEIP (normally it would be the same as MRES). Otherwise you can get into a mess because the motor record attempts to do a 'set position' each time UEIP is switched. So if ERES is wrong it would set an incorrect number of counts on the controller.
I think the logic there is something to do with wanting to keep RBV the same number if you switch UEIP.
Cheers,
Matt
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: 26 September 2012 15:28
> To: J. Lewis Muir; Pearson, Matthew (DLSLtd,RAL,DIA)
> Cc: [email protected]
> Subject: RE: Motor record -- URIP with soft limits
> On the Newport XPS we switch UEIP back and forth, depending on whether
> we want the RBV field to hold the theoretical position or encoder
> position. Sometimes one does not want to see the encoder jitter,
> sometimes one does. This can be changed at run-time with medm, etc.
> Mark
> From: [email protected] [[email protected]] on
> behalf of J. Lewis Muir [[email protected]]
> Sent: Wednesday, September 26, 2012 9:25 AM
> To: [email protected]
> Subject: Re: Motor record -- URIP with soft limits
> On 9/26/12 5:21 AM, [email protected] wrote:
> > Hi,
> > The pmacAsynMotor driver doesn't know about the motor record UEIP or
> URIP fields, as these are just internal to the motor record. But the
> driver does set the 'encoder present' bit in the MSTA field, allowing
> the use of UEIP to switch between REP and RMP for the position
> readback.
> Hi, Matt.
> Thanks for the info. I guess that means my motor records that
> use the pmacAsynMotor driver are configured incorrectly for what
> I want (i.e. having the RBV field reflect the position reported
> by the encoder). :-( I'll try changing them to have UEIP set to
> Yes.
> Thanks!
> Lewis
- Re: Motor record -- URIP with soft limits Ron Sluiter
- Motor record -- URIP with soft limits Fong, Nia W.
- Re: Motor record -- URIP with soft limits J. Lewis Muir
- Re: Motor record -- URIP with soft limits Ernest L. Williams Jr.
- RE: Motor record -- URIP with soft limits matthew.pearson
- RE: Motor record -- URIP with soft limits Mark Rivers
<2012>
2025
2026
<2012>
2025
2026
