Dear MotorRecord maintainers,
you can find my fix for the issue here:
https://github.com/mark0n/motorRecord
The repository also includes patches to eliminate some compiler
warnings. Feel free to cherry pick.
Please let me know if you have any concerns regarding the changes I made.
Martin
On 07/29/2013 03:18 PM, Konrad, Martin wrote:
> Hi,
>> I tested the OMS-58 and MSTA does update if the limit is disconnected
>> and STUP is set to 1.
> Mark, thanks for providing these details. With your information I was
> able to track the issue further down:
> Even with the "sendMsg = false;" line commented out in the device
> support, the MSTA field does not show a change in the limit-switch
> status while the motor is stopped (as far as I can see commenting out
> this line has no effect on the behavior at all).
> Sniffing the TCP connection between the IOC and the motor controller I
> learned that the issue is caused by the behavior of the motor controller
> which only transmits some sort of a "limit switch hit while moving"
> status as a response to the TAS (transmit axis data) command. In other
> words: The limit status in this message is not updated while the motor
> is stopped and triggering STUP is pretty useless (at least regarding the
> limit switches)...
> Nevertheless it is possible to read out the state of the limit inputs
> with the TLIM (transmit limits) or LIMFNC (input function for limit
> inputs) commands. Here is an example:
> # all limit switches in "ok" position:
>> TAS
> *TAS0000_0100_0000_0001_0000_0000_0000_0000
>> TLIM
> *TLIM110
>> LIMFNC
> *LIMFNC1-R POS LIMIT INPUT - STATUS ON
> *LIMFNC2-S NEG LIMIT INPUT - STATUS ON
> *LIMFNC3-T HOME LIMIT INPUT - STATUS OFF
> # negative limit switch pressed (while motor stopped):
>> TAS
>> TLIM
> *TLIM100
>> LIMFNC
> *LIMFNC2-S NEG LIMIT INPUT - STATUS OFF
> As far as I can see the PC6K device support should use one of TLIM or
> LIMFNC to determine the status of the limit switches. Can anyone of the
> maintainers confirm that? - I don't want to make changes to the code
> that do not have a chance to be included into the next version of motor
> record...
> Thanks for your help,
> Martin
- RE: motor record: continuously update limit switches Williams Jr., Ernest L.
- motor record: continuously update limit switches Konrad, Martin
- Re: motor record: continuously update limit switches Konrad, Martin
database breakpoint, dbb(), and large linksets John Dobbins
motorRecord simulation & STUP field Konrad, Martin
<2013>
2025
2026
RE: motor record: continuously update limit switches Mark Rivers
<2013>
2025
2026
