1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motorRecord simulation & STUP field
Date: Fri, 9 Aug 2013 15:37:31 +0000
> I'm also using R6-8 here.
> If you send me a tar file of your IOC, I'll build it here and see if I can reproduce it.
> Maybe a detailed Asyn trace would also help.
See attachment. Let me know if you need further details.
Martin
Attachment: testSimSupport.tar.bz2
Description: testSimSupport.tar.bz2
$ ./st.cmd
#!../../bin/linux-x86_64-debug/testSimSupport
## You may have to change testSimSupport to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64-debug")
epicsEnvSet("IOC","ioctestSimSupport")
epicsEnvSet("TOP","/home/marko/work/stripperFoilPlatter/motorTest/testSimSupport")
epicsEnvSet("ASYN","/usr/lib/epics")
epicsEnvSet("MOTOR","/usr/lib/epics")
epicsEnvSet("EPICS_BASE","/usr/lib/epics")
cd /home/marko/work/stripperFoilPlatter/motorTest/testSimSupport
dbLoadDatabase "dbd/testSimSupport.dbd"
testSimSupport_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadRecords "db/matt.db"
# Create simulated motors: ( start card , start axis , low limit, high limit, home posn, # cards, # axes to setup)
motorSimCreate( 0, 0, -150000000, 150000000, 0, 1, 2 )
Creating motor simulator: card: 0, axis: 0, hi: 150000000, low -150000000, home: 0, ncards: 1, naxis: 2
Created motor for card 0, signal 0 OK
Created motor for card 0, signal 1 OK
# Setup the Asyn layer (portname, low-level driver drvet name, card, number of axes on card)
drvAsynMotorConfigure("sim1", "motorSim", 0, 2)
asynSetTraceMask("sim1",-1,-1)
cd /home/marko/work/stripperFoilPlatter/motorTest/testSimSupport/iocBoot/ioctestSimSupport
iocInit
Starting iocInit
## EPICS R3.14.12.3-6 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built May 22 2013
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_MOVE_REL, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_MOVE_REL
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_MOVE_ABS, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_MOVE_ABS
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_MOVE_VEL, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_MOVE_VEL
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_HOME, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_HOME
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_STOP_AXIS, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_STOP_AXIS
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_VELOCITY, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_VELOCITY
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_VEL_BASE, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_VEL_BASE
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_ACCEL, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_ACCEL
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_POSITION, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_POSITION
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_RESOLUTION, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_RESOLUTION
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_ENC_RATIO, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_ENC_RATIO
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_PGAIN, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_PGAIN
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_IGAIN, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_IGAIN
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_DGAIN, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_DGAIN
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_HIGH_LIMIT, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_HIGH_LIMIT
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_LOW_LIMIT, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_LOW_LIMIT
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_SET_CLOSED_LOOP, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_SET_CLOSED_LOOP
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_STATUS, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_STATUS
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, drvInfo=MOTOR_UPDATE_STATUS, pptypeName=(nil), psize=(nil), pasynUser=0xc99d58
2013/08/09 11:34:23.346 drvMotorAsyn::drvUserCreate, command=MOTOR_UPDATE_STATUS
2013/08/09 11:34:23.346 sim1 1 registerInterruptUser
2013/08/09 11:34:23.346 drvMotorAsyn::readMotorStatus, [00000000,0.000000,0.000000,0.000000]
2013/08/09 11:34:23.346 devMotorAsyn::init_controller, mkp:Mot:Sim1 setting of position not required, position=0.000000, mres=0.001000, dval=0.000000, rdbd=0.0010002013/08/09 11:34:23.346 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=1
2013/08/09 11:34:23.346 devMotorAsyn::send_msg: mkp:Mot:Sim1 command=19, pact=0
2013/08/09 11:34:23.346 sim1 addr 1 queueRequest priority 0 not lockHolder
2013/08/09 11:34:23.346 devMotorAsyn::send_msg: mkp:Mot:Sim1 command=20, pact=0
2013/08/09 11:34:23.346 sim1 1 autoConnect
2013/08/09 11:34:23.346 drvMotorAsyn::connect, pasynUser=0xc96bc8
2013/08/09 11:34:23.347 asynManager::portThread port=sim1 callback
2013/08/09 11:34:23.347 devMotorAsyn::asynCallback: mkp:Mot:Sim1 command=14, ivalue=0, dvalue=50000000000.000000
2013/08/09 11:34:23.347 drvMotorAsyn::writeFloat64, reason=4, pasynUser=0xca8368 pAxis=0xc98df8
2013/08/09 11:34:23.347 Set card 0, axis 1 high limit to 50000000000.0000002013/08/09 11:34:23.347 mkp:Mot:Sim1 devMotorAsyn::statusCallback new value=[p:0.000000,e:0.000000,s:0]
2013/08/09 11:34:23.347 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=1
2013/08/09 11:34:23.347 drvMotorAsyn::writeFloat64, reason=4, value=50000000000.000000
2013/08/09 11:34:23.347 devMotorAsyn::asynCallback: mkp:Mot:Sim1 command=15, ivalue=0, dvalue=-50000000000.000000
2013/08/09 11:34:23.347 drvMotorAsyn::writeFloat64, reason=3, pasynUser=0xca8578 pAxis=0xc98df8
2013/08/09 11:34:23.347 Set card 0, axis 1 low limit to -50000000000.0000002013/08/09 11:34:23.347 mkp:Mot:Sim1 devMotorAsyn::statusCallback new value=[p:0.000000,e:0.000000,s:0]
2013/08/09 11:34:23.347 drvMotorAsyn::writeFloat64, reason=3, value=-50000000000.000000
2013/08/09 11:34:23.445 mkp:Mot:Sim1 devMotorAsyn::statusCallback new value=[p:0.000000,e:0.000000,s:a]
2013/08/09 11:34:23.445 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=1
## Start any sequence programs
#seq sncxxx,"user=markoHost"
epics> dbpr mkp:Mot:Sim1 4
ACCL: 0.1           ACKS: INVALID       ACKT: YES           ADEL: 0.5
ALST: 0             ASG:                ASP: (nil)          ATHM: 1
BACC: 0.1           BDST: 0             BKPT: 00            BVEL: 0
CARD: -1            CBAK: 0xca7650      CDIR: 0             CNEN: Disable
DCOF: 0             DESC: sim           DHLM: 50000000      DIFF: 0
DINP:CONSTANT       DIR: Pos            DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DLLM: -50000000     DLY: 0
DMOV: 1             DOL:CONSTANT        DPVT: 0xca7680      DRBV: 0
DSET: 0x7f0501e58880                    DTYP: asynMotor     DVAL: 0
EGU: mm             ERES: 1.0e-03       EVNT: 0             FLNK:CONSTANT 0
FOF: 0              FOFF: Variable      FRAC: 1             HHSV: NO_ALARM
HIGH: 0             HIHI: 0             HLM: 50000000       HLS: 0
HLSV: MINOR         HOMF: 0             HOMR: 0             HOPR: 0
HSV: NO_ALARM       HVEL: 0             ICOF: 0             INIT:
JAR: 50             JOGF: 0             JOGR: 0             JVEL: 5
LCNT: 0             LDVL: 0             LLM: -50000000      LLS: 0
LLSV: NO_ALARM      LOCK: NO            LOLO: 0             LOPR: 0
LOW: 0              LRLV: 0             LRVL: 0             LSET: 0xca8830
LSPG: Go            LSV: NO_ALARM       LVAL: 0             LVIO: 0
MDEL: 0             MIP: 0              MISS: 0
MLIS: 80 69 02 a0 04 7f 00 00 80 69 02 a0 04 7f 00 00 01 00 00 00
MLOK: 50 74 ca 00 00 00 00 00           MLST: 0             MMAP: 0
MOVN: 0             MRES: 1.0e-03       MSTA: 10            NAME: mkp:Mot:Sim1
NMAP: 0             NSEV: NO_ALARM      NSTA: NO_ALARM      NTM: YES
NTMF: 2             OFF: 0              OMSL: supervisory
OUT:INST_IO @asyn(sim1,1)               PACT: 0             PCOF: 0
PHAS: 0             PINI: NO            POST:               PP: 0
PPN: (nil)          PPNR: (nil)         PREC: 3             PREM:
PRIO: LOW           PROC: 0             PUTF: 0             RBV: 0
RCNT: 0             RDBD: 1.0e-03       RDBL:CONSTANT       RDES: 0xc88450
RDIF: 0             REP: 0              RHLS: 0             RINP:CONSTANT
RLLS: 0             RLNK:CONSTANT       RLV: 0              RMOD: Default
RMP: 0              RPRO: 0             RRBV: 0             RRES: 0
RSET: 0x7f0501e58440                    RTRY: 0             RVAL: 0
RVEL: 0             S: 25               SBAK: 0             SBAS: 0
SCAN: Passive       SDIS:CA_LINK mkp:Mot:Sim1:SDIS.VAL NPP NMS
SET: Use            SEVR: INVALID       SMAX: 25            SPMG: Go
SPVT: (nil)         SREV: 200           SSET: 0             STAT: LINK
STOO:CONSTANT       STOP: 0             STUP: OFF           SUSE: 0
SYNC: 0             TDIR: 0             TIME: 2013-08-09 11:34:23.445372534
TPRO: 0             TSE: 0              TSEL:CONSTANT       TWF: 0
TWR: 0              TWV: 1              UDF: 0              UEIP: No
UREV: 0.2           URIP: No            VAL: 0              VBAS: 0
VELO: 5             VERS: 6.7           VMAX: 5             VOF: 0
epics> dbpf mkp:Mot:Sim1.STUP 1
2013/08/09 11:34:35.688 mkp:Mot:Sim1 devMotorAsyn::update_values, needUpdate=0
2013/08/09 11:34:35.688 devMotorAsyn::send_msg: mkp:Mot:Sim1 command=10, pact=1
2013/08/09 11:34:35.688 sim1 addr 1 queueRequest priority 0 not lockHolder
2013/08/09 11:34:35.688 asynManager::portThread port=sim1 callback
DBR_STRING:          "BUSY"
2013/08/09 11:34:35.688 devMotorAsyn::asynCallback: mkp:Mot:Sim1 command=18, ivalue=0, dvalue=0.000000
2013/08/09 11:34:35.688 drvMotorAsyn::writeInt32, reason=109, value=0
STOO:CONSTANT       STOP: 0             STUP: BUSY          SUSE: 0
SYNC: 0             TDIR: 0             TIME: 2013-08-09 11:34:35.688013330
epics>
Re: motorRecord simulation & STUP field Pearson, Matthew R.
motorRecord simulation & STUP field Konrad, Martin
Re: motorRecord simulation & STUP field Ron Sluiter
Re: motorRecord simulation & STUP field Konrad, Martin
Prev: Re: [asyn] link already open! Pavel Maslov
Next: Re: motorRecord simulation & STUP field Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motorRecord simulation & STUP field Pearson, Matthew R.
Next: Re: motorRecord simulation & STUP field Pearson, Matthew R.
