1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: garbage in zero length arrays
To: Mezger Anton Christian <[email protected]>
Date: Fri, 17 Jan 2014 17:07:50 +0000
Hi Anton,
Thanks for taking some time to report this issue.
I will emulate the typical computer support personal and respond to a question with an escalating number of questions :-).
Ø  The Array has  zero length (NORD=0) after boot. Then I get garbage as first
Ø  character while the number of elements is 128 in my case and this number
Ø  was requested. When specifying 0 at request I get args.count=0 as it should
Ø  with 3.14.12.
o Is this issue repeatable when testing with a different client side code other than caget? If so, which ca client code is in use?
o Is this issue repeatable when testing with multiple record types and or multiple device support modules?
o You mention that the issue is related to NORD being zero just after booting the IOC. Does the problem persist or does it happen only once; if it doesn’t persist then what is the action that causes an improvement? For example, I could imagine some different scenarios where the behavior might improve the second time that a CA client attaches, in a particular client’s second subscription update, the first time that the record processes, or the second time that the record processes.
o In what versions of EPICS does it fail, and in  what versions does it work correctly; is it working correctly in 3.14.12?
Thanks for your help.
best regards,
Jeff
From: Mezger Anton Christian [mailto:[email protected]]
Sent: Thursday, January 16, 2014 9:24 AM
To: Hill, Jeff
Cc: [email protected]
Hi Jeff,
The Array has  zero length (NORD=0) after boot. Then I get garbage as first character while the number of elements is 128 in my case and this number was requested. When specifying 0 at request I get args.count=0 as it should with 3.14.12.
Regards
Anton
__________________________________________
Paul Scherrer Institut
Dr. Anton Christian Mezger
WBGB/103
CH-5232 Villigen PSI
Telefon: +41 56 310 34 06
E-Mail: [email protected]
Sent: Donnerstag, 16. Januar 2014 17:20
Anton,
As memory serves, a request for a zero length subscription will probably be rejected by an old version of the CA server.
Jeff
Sent: Thursday, January 16, 2014 9:12 AM
To: Hill, Jeff; [email protected]
Thank you Jeff,
this confirms that I can set 0 in the ca_add_event_array. In any case of epics combinations (ioc, client) that would work properly at monitor receive.
Thanks and best regards
Anton
WBGB/103
Sent: Donnerstag, 16. Januar 2014 17:07
To: Mezger Anton Christian; [email protected]
Ø  My question is: when specifying 0, how does that behave in older epics versions and channel
Ø  access gateways. Does it use then the maximum amount of elements ?
When a channel connects the maximum number of elements is supplied by the server as a channel attribute. In newer versions of EPICS the current number of elements is returned with each subscription update. In older versions the maximum number of elements was always returned; when the current number of elements was less than the maximum number then any additional elements at the end were zero padded.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Mezger Anton Christian
Sent: Thursday, January 16, 2014 4:46 AM
To: [email protected]
Subject: garbage in zero length arrays
Hi all,
When monitoring a non initialized char array with ca_add_event_array, one gets most of the time in the first element of the array.
This only when the request uses ca_element_count(chid) which is non zero. When using the dynamic behavior by specifiying 0 elements, the received args.count correspond to the actual size of the array, including zero when not initialized.
My question is: when specifying 0, how does that behave in older epics versions and channel access gateways. Does it use then the maximum amount of elements ?
Anton
WBGB/103
RE: garbage in zero length arrays Mezger Anton Christian
RE: garbage in zero length arrays Hill, Jeff
Prev: Re: A call to 'assert(capacity != 0)' by thread‏ Benjamin Franksen
Next: RE: garbage in zero length arrays Mezger Anton Christian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: garbage in zero length arrays Mezger Anton Christian
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
