1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem
To: Michael Westfall <[email protected]>
Cc: [email protected]
Date: Thu, 3 Dec 2015 10:25:08 -0600
On 12/03/2015 09:44 AM, Michael Westfall wrote:
> Next question:
> It looks like libbspExt installs in
> <rtems_prefix>/target/ssrlApps/<arch>/<bsp>/lib
> What do I need to do to make base-3.14.12.5 look there when linking?
> Or is there a way to get libbspExt to install in the standard bsp lib
> directory?
That may be what the --enable-std-rtems-installdirs option to configure
does; I must have read about that in the module's INSTALL instructions
since I have no idea where else I'd have come across it, it's not
mentioned in Eric's tutorial but is in mine.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Andrew Johnson
Prev: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Next: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
