1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem
Cc: [email protected]
Date: Thu, 3 Dec 2015 14:10:49 -0300
Ah, yes. That's what works.
Thank you.
On Thu, Dec 3, 2015 at 1:25 PM, Andrew Johnson <[email protected]> wrote:
That may be what the --enable-std-rtems-installdirs option to configure
does;
Mike Westfall
Gemini Observatory
Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Andrew Johnson
Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Michael Westfall
Prev: Re: Epics base-3.14.12.5 / RTEMS-4.10 /beatnik compile problem Andrew Johnson
Next: RE: ai RVAL via asyn + modbus: getting unsigned integer jon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: migration from old EPICS Base Jiro Fujita
