It looks to me like the build completely succeeded. You have some funny looking stuff at the end of the output file, but that looks like some "ls" commands, but it completed building the cap5 directory, which is the last thing to be built.
Sent: Thursday, December 10, 2015 8:12 AM
To: Mark Rivers; [email protected]
Subject: RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
UNRESTRICTED / ILLIMITÉE
Hi Mark,
I did as you suggested and it did build as more complete bin directory:
:/usr/local/epics/base-3.14.12.3$ ls bin/linux-x86/
acctst casw iocLogServer
aitGen ca_test makeBaseApp.pl
antelope catime makeBaseExt.pl
ascheck convertRelease.pl makeBpt
caConnTest cvsclean.pl makeIncludeDbd.pl
caDirServ dbExpand makeMakefile.pl
caEventRate dbReadTest makeTestfile.pl
caget dbToMenuH mkmf.pl
caget.pl dbToRecordtypeH munch.pl
cainfo dos2unix.pl registerRecordDeviceDriver.pl
cainfo.pl e_flex replaceVAR.pl
camonitor excas S99caRepeater
camonitor.pl expandVars.pl S99logServer
capr.pl filterWarnings.pl softIoc
caput fullPathName.pl useManifestTool.pl
caput.pl genApps
caRepeater installEpics.pl
I've attached my terminal session: epicsbuild.term
-----Original Message-----
Sent: December-09-15 1:36 PM
To: Cusick, Martin-Lee; [email protected]
Hi Lee,
Can you send the complete output when you do the following at the top level of base-3.14.12.3.
setenv EPICS_HOST_ARCH linux-x86
make clean
make
Note in your original message you said:
> I have the gcc-multilib package, and lib32, and I followed this advice:
> base/configure/os/CONFIG_SITE.linux-x86.Common:
> # T.S, 2006/09/05
> # add -m32 so we create 32-bit code when
> # executing on 64-bit machine with EPICS_HOST_ARCH=linux-x86
> ARCH_DEP_CFLAGS+=-m32
> ARCH_DEP_CXXFLAGS+=-m32
> ARCH_DEP_LDFLAGS+=-m32
The tech-talk link you pointed to was for a very old release of base, 3.14.8 which is when 64-bit support was just beginning. You should NOT make those edits in 3.14.12.3, it is all taken care of in the standard distribution. I build linux-x86 on a 64-bit Linux system all the time without any edits to CONFIG_SITE.linux-x86.Common.
From: Cusick, Martin-Lee [mailto:[email protected]]
Sent: Wednesday, December 09, 2015 12:19 PM
Hi Mark,
Thanks for the prompt reply.
I did have the correct links, but I found this out with some tinkering it was actually a missing g++ library that solved my problem.
I had to install g++-multilib, that solved the libstdc++ link issue.
My three builds built, but I know have a separate issue. Please review it to determine if I should post it to another subject.
base/bin:
/usr/local/epics.bak/base-3.14.12.3/bin$ ls
linux-arm-rpi linux-x86 linux-x86_64
ls arm:
/usr/local/epics.bak/base-3.14.12.3/bin$ ls linux-arm-rpi/
caput.pl genApps
Which looks complete.
Ls x86_64:
/usr/local/epics.bak/base-3.14.12.3/bin$ ls linux-x86_64
caput.pl genApps
Good.
Ls x86:
convertRelease.pl filterWarnings.pl makeBaseExt.pl mkmf.pl
cvsclean.pl fullPathName.pl makeIncludeDbd.pl munch.pl
dos2unix.pl installEpics.pl makeMakefile.pl replaceVAR.pl
expandVars.pl makeBaseApp.pl makeTestfile.pl useManifestTool.pl
Missing a lot of tools here.
Please tell me your thoughts.
Thanks so much,
Lee
Sent: December-09-15 12:24 PM
Subject: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
Are you sure you have installed both the 64-bit and 32-bit versions of the system library libstdc++.so?
Here are the files on my Fedora system:
7233436 0 lrwxrwxrwx 1 root root 37 Apr 10 2012 /usr/lib/gcc/x86_64-redhat-linux/4.6.3/libstdc++.so -> ../../../../lib64/libstdc++.so.6.0.16
7233434 0 lrwxrwxrwx 1 root root 31 Apr 10 2012 /usr/lib/gcc/x86_64-redhat-linux/4.6.3/32/libstdc++.so -> ../../../../libstdc++.so.6.0.16
Note that there are both 64-bit and 32-bit versions of that library.
Do you find both 64-bit and 32-bit versions of libstdc++.so on your system?
From: [email protected] [mailto:[email protected]] On Behalf Of Cusick, Martin-Lee
Sent: Wednesday, December 09, 2015 9:00 AM
To: [email protected]
Subject: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
OFFICIAL USE ONLY / À USAGE EXCLUSIF
Hello,
I will start will giving some of the environment details:
Host Machine:
Ubuntu 12.04 (3.13.0-71-generic kernel) x86_64
I am building IOC's for 64 and 32-bit machines; I am also cross compiling for ARM (Raspberry Pi), with crosstools-ng.
The build is successful for 64 bit binaries and the 32-bit cross compile, but I keep getting an error for x86:
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.so when searching for -lstdc++
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.a when searching for -lstdc++
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src'
make: *** [src.install] Error 2
# T.S, 2006/09/05
Thanks you in advance for your help,
Lee
- EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
- RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
- RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
- RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
Alarm handling Henrique Almeida
<2015>
2025
2026
Re: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Michael Davidsaver
<2015>
2025
2026
