1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tech-talk Digest, Vol 9, Issue 397
To: [email protected]
Date: Mon, 28 Dec 2015 10:07:57 +0900
Re:  Problem: nozzle exchanger Local/Remote pv value is not
      received (???)
Thank for your help
but i don't know How to detect some problem....
How can i see the problem with communication with the device
if these text are added, where can i see?
2, 9  number what is mean?
>You should enable asynTrace on the $(PORT) and $(A) to see what is actually happening with communication with the device.
>asynSetTraceIOMask($(PORT), $(A), 2)
>asynSetTraceMask($(PORT), $(A), 9)
>Mark
---------- Forwarded message ----------
Date: 2015-12-25 3:00 GMT+09:00
Subject: Tech-talk Digest, Vol 9, Issue 397
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
        [email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. Re: EPICS synApps installation ERROR. Please, Help me.
      (Pete Jemian)
   2. Re: EPICS synApps installation ERROR. Please, Help me.
      (Mark Engbretson)
   3. Problem: nozzle exchanger Local/Remote pv value is not
      received (???)
   4. Re: Problem: nozzle exchanger Local/Remote pv value is not
      received (Mark Rivers)
   5. APS Shutdown and Network Maintenance (Johnson, Andrew N.)
Message: 1
Date: Wed, 23 Dec 2015 12:00:21 -0600
To: <[email protected]>
Subject: Re: EPICS synApps installation ERROR. Please, Help me.
Message-ID: <[email protected]" target="_blank">[email protected]>
Content-Type: text/plain; charset="utf-8"; format=flowed
The synApps has a different build structure than the EPICS extensions.
If synApps is installed in the extensions/src directory, it is not
likely to be built at all.
The README file at the base of the synApps directory structure
(https://github.com/EPICS-synApps/support/blob/master/README) has build
instructions.
Which synApps version are you installing?
Did you get it from a .tar.gz file or from a source code repository?
Can you send the complete output from your gmake command?
Pete
On 12/22/2015 8:06 PM, [email protected] wrote:
> hello.
> Pleas, Help me.
> I have some questions about EPICS installation.
> I use "fedora 20" with "Cinnamon desktop". User name is "cha"
> I installed the synApp in extensions directory and everything is fine
> (no any error come out from gmake).
> But when i check the file in extensions directory, The gmake did not
> build the "lib" directory.
> I am not sure why is happened, If you a a time and have some
> suggestions please would you let  me know???
> The extensions folder contains: bin, configure, html, Makefile,  README,
> and src
> But, no have "lib".
> I totally 10 time format and install again. again again.
> what's problems? please, help me
> Thanks.
> Cha
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
    Education is the one thing for which people
       are willing to pay yet not receive.
Message: 2
Date: Wed, 23 Dec 2015 14:41:33 -0600
To: Pete Jemian <[email protected]>
Cc: [email protected]
Content-Type: text/plain;       charset=us-ascii
Synapps is also NOT a single product. It is a grouping of different modules so any bin and lib files would be under the actual product directory, not in any sort of master bin, include, or lib files. This is because versions of everything change a lot, so would be harder to know exactly what you are building against if you had multiple versions.
If synApps is installed in the extensions/src directory, it is not likely to be built at all.
The README file at the base of the synApps directory structure (https://github.com/EPICS-synApps/support/blob/master/README) has build instructions.
Pete
> hello.
> Pleas, Help me.
> and src
> But, no have "lib".
> Thanks.
> Cha
Message: 3
Date: Thu, 24 Dec 2015 14:14:27 +0900 (KST)
Subject: Problem: nozzle exchanger Local/Remote pv value is not
        received
 Hello..
i'm reparing the ioc of Nozzle Exchanger.
Now, pv value (Local/Remote) is viewing in medm... but this is decoy... i think it is default value.
when i switch Remote/Local S/W in Nozzle Exchanger, pv value in medm is not changed.
this pv value is a valuable data?
 i know "st.cmd" deamon is ioc deamon. so i stoped "st.cmd" deamon.
and i see all of pv value in medm is blanked. and i started "st.cmd" so, i see all of py value is displayed (but these value is not correct)
and i updated .db of device and i restart ioc deamon
i add the pv object in medm. and i see the  default value of added pv in medm
is this situation correct?
somthing is missed..
devNozzleExchange.db
record(bi, "$(P)$(D):GetRemoteSta")
    field(DESC, "Local/Remote Status")
    field(DTYP, "stream")
    field(INP,  "@devNozzleExchange.proto GetRemoteSta $(PORT) $(A)")
    field(ZNAM, "Local")
    field(ONAM, "Remote")
    field(SCAN, ".2 second")
    field(FLNK, "$(P)$(D):GetCryoSolSta")
devNozzleExchage.proto
@writetimeout { disconnect; }
@replytimeout { disconnect; }
@readtimeout  { disconnect; }
@mismatch     { disconnect; }
ReplyTimeout = 1200;
InTerminator = "\r\n";
OutTerminator = "\r\n";
# Measure current
GetRemoteSta {
    out "!50SWS";
    in "?50%1d";
    ExtraInput = Ignore;
GetCryoSolSta {
    out "!51SOL";
    in "?51%1d%*2d";
.....-----------------------------------------------------------------------------this is code...
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20151224/e72423b4/attachment.html>
Message: 4
Date: Thu, 24 Dec 2015 15:06:15 +0000
To: ??? <[email protected]>
Subject: Re: Problem: nozzle exchanger Local/Remote pv value is not
        received
Content-Type: text/plain; charset="ks_c_5601-1987"
Sent from my iPhone
On Dec 24, 2015, at 3:13 AM, ??? <[email protected]<mailto:[email protected]>> wrote:
Hello..
# Measure current
GetRemoteSta {
    out "!50SWS";
    in "?50%1d";
GetCryoSolSta {
    out "!51SOL";
    in "?51%1d%*2d";
this is code...
[???]<http://blog.naver.com/pmjzzang78.do>      ??<http://blog.naver.com/pmjzzang78.do>
[http://mail.naver.com/readReceipt/notify/?img=bdRCDNG8WBgZhAn%2FFr%2B5FzJSM4K9MouXFzuZKrpCKqgwFzkvKxi4p6FCazEdpvIo%2BrkSKoU5W4d5W4C5bX0q%2BzkR74FTWx%2Fs%2Bzko1V9dM6wOtzJmbZlCW4m5prer.gif]
Message: 5
Date: Thu, 24 Dec 2015 16:49:38 +0000
Subject: APS Shutdown and Network Maintenance
Content-Type: text/plain; charset="us-ascii"
Users of tech-talk and the EPICS website are warned that this mailing list and the website are likely to be affected by the maintenance work that our IT group will be performing on the APS network and servers over the next week or two after Christmas. Email sent to tech-talk while the servers are down should be queued up for eventual delivery, so please don't re-send any messages that don't appear to get through unless you get a final notice from the postmaster that your message cannot be delivered. Things should be mostly back to normal by January 4th when Argonne re-opens, although short-term outages could still occur after that date.
Wishing everyone an enjoyable holiday season.
- Andrew
Sent from my iPad
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 9, Issue 397
RE: Tech-talk Digest, Vol 9, Issue 397 Mark Rivers
Prev: APS Shutdown and Network Maintenance Johnson, Andrew N.
Next: RE: Tech-talk Digest, Vol 9, Issue 397 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 27 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
