1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: OS X edm/medm openmotif woes
To: Rod Nussbaumer <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 16 Nov 2016 15:42:16 +0000
No.  In this case, on-demand means when a person chooses to execute the "make" command in the directory with the changed .adl file(s).
Sent from a device with a dreadfully small screen
-------- Original message --------
Date: 11/16/16 9:24 AM (GMT-06:00)
To: [email protected]
Subject: Re: OS X edm/medm openmotif woes
Pete:
Does 'on-demand scripted conversion' mean that the conversion takes
place immediately before the screen is displayed, and as often as the
screen is displayed? I presume that this requires some built-in support
from caQtDM to accomplish this?
Rod Nussbaumer
TRIUMF,
Vancouver, Canada
On 11/16/2016 06:30 AM, Pete Jemian wrote:
> The workflow BCDA is using to support its beam lines at the APS to
> transition from MEDM to caQtDM is
> 1. implement on-demand scripted conversion from .adl to .ui files
> 2. beam lines to use caQtDM when screens are ready
> 3. continue to edit screens as .adl files during transition
> and convert to .ui (choices managed by a Makefile rule)
> 4. train facility staff to use Qt Designer
> 5. edit screens in Qt Designer
> 6. discontinue MEDM altogether
> Hope to complete that by spring 2017
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes J. Lewis Muir
Re: OS X edm/medm openmotif woes Matt Newville
Re: OS X edm/medm openmotif woes Pete Jemian
Re: OS X edm/medm openmotif woes Rod Nussbaumer
Prev: Re: OS X edm/medm openmotif woes Rod Nussbaumer
Next: Philosophy regarding use of open source libraries for EPICS Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: OS X edm/medm openmotif woes Mark Rivers
ANJ, 16 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
