On 11/17, Wang Xiaoqiang (PSI) wrote:
> Hi Lewis,
> After checking, my medm is linked only to MacPorts libraries.
Hi, Xiaoqiang.
OK, thanks for confirming.
> As you said, the key issue is the flat_namespace flag. Luckily
> Macports handles that automatically if the xorg-libXt is installed as
> a dependency to openmotif.
I'm not a MacPorts expert, but my understanding is that it does *not*
handle that automatically. If you update your local ports tree and
rebuild, I think it will fail on x11/openmotif because x11/xorg-libXt
was not built as a flat-namespace shared library. In order to build
x11/xorg-libXt as a flat-namespace shared library, you will need to
enable the flat_namespace variant for x11/xorg-libXt. That doesn't
happen automatically.
Lewis
- Re: OS X edm/medm openmotif woes Wang Xiaoqiang
- OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes Jiro Fujita
- Re: OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes J. Lewis Muir
- Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
RE: ERROR -111 in Keithley6485 Mark Rivers
StreamDevice fails to compile for RTEMS Michael Westfall
<2016>
2025
2026
<2016>
2025
2026
