1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: "J. Lewis Muir" <[email protected]>
Cc: Epics <[email protected]>
Date: Thu, 17 Nov 2016 16:52:33 +0100
Hi Lewis,
Last time (3 years ago) during the fresh installation, I did not remember tuning for flat_namespace variant.
But I will keep this in mind in case of I need to make a fresh install.
Thanks.
Best
Xiaoqiang
On 11/17/2016 04:43 PM, J. Lewis Muir wrote:
On 11/17, Wang Xiaoqiang (PSI) wrote:
Hi Lewis,
After checking, my medm is linked only to MacPorts libraries.
Hi, Xiaoqiang.
OK, thanks for confirming.
As you said, the key issue is the flat_namespace flag. Luckily
Macports handles that automatically if the xorg-libXt is installed as
a dependency to openmotif.
I'm not a MacPorts expert, but my understanding is that it does *not*
handle that automatically.  If you update your local ports tree and
rebuild, I think it will fail on x11/openmotif because x11/xorg-libXt
was not built as a flat-namespace shared library.  In order to build
x11/xorg-libXt as a flat-namespace shared library, you will need to
enable the flat_namespace variant for x11/xorg-libXt.  That doesn't
happen automatically.
Lewis
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes J. Lewis Muir
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
Prev: StreamDevice fails to compile for RTEMS Michael Westfall
Next: Re: OS X edm/medm openmotif woes Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OS X edm/medm openmotif woes J. Lewis Muir
ANJ, 17 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
