Hi Kevin, Ben,
On Thu, Dec 1, 2016 at 6:21 AM, Benjamin Franksen <[email protected]> wrote: On 01.12.2016 10:15, Kevin Meyer wrote: Pyepics does provide 'ca.current_context()', 'ca.attach_context()', 'ca.detach_context()' and so on. These are very thin wrappings of those provided from the C CA library. By default, the initial context (that is, the one automatically created on the first access to the CA library) is used for all CA connections. You have to explicitly tell pyepics to not do this. > 3. The susceptible sequencer still works fine if I stop one of the By default, pyepics uses preemptive callbacks for nearly all connections. To disable this, do import epics epics.ca.PREEMPTIVE_CALLBACK = False prior to creating any connections. Or, if you're creating contexts yourself, you can also use import epics epics.ca.context_create(0) to create a context that does not use preemptive callbacks. For Kevin's observation that some 'epics.caget(xxx)' calls work: Are these channels connecting *only* from Python, or are they also connected by CA in the sequence program? I don't know of anyone using pyepics from an embedded C program, including an SNL program. If that process is also doing CA calls, I can believe there could be trouble. I don't think it *has* to fail, but I think you might be the first person to try this. As an alternative way of looking at the problem: Is more work being done in the SNL code or in the Python code? If most of the work is in Python, would it be plausible to move all the logic from the SNL code to a python process? Pyepics doesn't provide a built-in finite-state-machine, but these are not too hard to write in python. There are some advantages to having PVs defined loaded and defined in an IOC and all the logic that interacts with those PVs in a separate process. That's not saying you shouldn't use the amazing sequencer, but sometimes what you really want is a small program that operates on a set of PVs. --Matt Newville
| ANJ, 02 Dec 2016 |
Home
News
About
Talk
Base
Modules
Extensions
